ugh I hate posting asking for help...99 tj 3" lift
You don't need adjustable uppers. The toe is wrong. The caster might be wrong. You can adjust the caster with the lower cam bolts. If that doesn't get you close, throw the cheapest set of aftermarket lowers on it you can find. They don't need to be adjustable. A set of Rough Country poop pipe lowers can be found for $20 or so, and are longer than the factory sheet metal lowers.
Think i need to slide axle over some , double check when i get home.
