UN wrap a leaf ?
Rockeater
Trinity/High Point NC
OK, I've got a less than arched rear leaf spring on the Jeep. Can the spring be rearched by me and a teleshone pole and winch ? Sent to spring shop ? Other options ? And yes I post in the Wanted section. :)
Thanks
J(sees a leaf spring crossbow, with a telephone pole)B
Do you mean that you've got a leaf that had been negatively arched by an obstacle or something?
I had one like that and simply put it in a press and straightened it. The rest of the pack was in good shape.
If you are looking for a lift I'd run it in to any steel fab shop and have them roll it for you. As you know the lift will settle out over time.
It's a YJ 4in lift spring that now as a slight S shape and is squatting.
I really only need one replacement.
JB
you could try to take leaf pack aprt and run the top leaf through a slip roller.. may work but leafs are heat treated so it may not...
