I didn't get to see it on the work day, but unless they filled in the rut on the right hand side of the hill climb I wouldn't do it in a stock Liberty. But that is just me. I mean it could be doable in a stock Liberty, its just don't be surprised if you end up against the wall where the rut is.
I took the advice given to me on the map and updated a few things, plus some things that changed via the work day etc:
- Increased the Size of the Borders on the trail information blocks
- Changed "Extremely Difficult" and "Easy" to reflect a "Easiest" to "Most Difficult" rating system. Also put ("Based on a stock vehicle") back on the bottom.
- Removed a bypass on Falls Dam (we put up guard rail), and added a couple bypasses on Dickey Bell.
- Add more specifics to the Obstacles of Interest including more up to date names. For example on Falls Dam for a long time now the "Mud Pits" have had their own names. So I put the "Soup Bowl" and the "Ledges Mud Pit" to replace the generic "Mud Pits". Also since over the years (and brought up in this thread) the area that was just known for Kodak Rock has grown into a Rock Garden with multiple obstacles including Budweiser Rock and others. So to keep with the growth of the obstacle and to avoid further confusion it is now the Kodak Rock Garden. And on Daniel I reverted back to the old name for the Hill Climb since the bypass was re-opened halfway through last year, so it is now once again the "3 Path Hill".
- Added "Road Warnings" to the Map Key, and added 2 more to the map. Including a warning for the very steep/sharp S-turn that has a nice drop off on it. That can be a very dangerous turn if you are going one way, and a guy with a trail comes down the other.
- Add Stop Sign labels for those first timers wondering where the turns/intersections are at. So you know when you see the stop sign without referencing the map for road names/numbers that you are where you need to turn.
- To help with the location of the upper entrance (since there isn't a big "Uwharrie Sign") I also have denoted the location of the smaller brown forest service sign that reads "Badin Lake Recreation Area" with a little white arrow this is located right where you need to turn.
- Moved the trail label for Falls Dam so I could make the "Tread Lightly" logo a little bit larger/readable.
