gmcjimmy88
- May 15, 2005
- Fayetteville
Not sure if this is even on the same level as to what you guys are referring to but, I know certain Aircraft that injects water to increase power for take-off.
x2
The basic idea is that you split up water (H20) and then combine it back again. The process of combining it via combustion gives off energy, which you harness to make the car go.
Sadly, the energy used to combine the gases can't be greater than the energy it took to split up the water in the first place. In a perfect theoretical world you break even. In the real world there is wasted energy in both the splitting and the combining so you're at a loss. It's a waste of time, you can't run your car on water. Some thing in science are just understood and won't be changing, this is one of those things.
I'm more excited about pure electric cars or hybrids that only use gas when the batteries are low but are normally charged by plugging them in. When we have that, we can focus on large scale green energy sources like solar, nuclear, wind, hydroelectric, etc. (Ok, they aren't perfectly green but they are all better than coal.)
right....but its the type of energy you use to split the atoms. I have no idea how these set ups are working, but a am going to assume the use electricity from the battery or altenator. Neither are power sources used in propulsion of the vehicle. So...you are not creating energy or magnifying it. Your transfering it from one vehicle system to the other.
....... its not like when you turn on your lights or radio you lose gas mileage.....
the alt use the same amount of "fuel" if its putting our power or not (drag on the pulley)
Actually, not true. As current being made by the alternator goes up, it becomes harder to spin. If there was nothing using current from it, it would spin freely, and become harder to spin the more amperage it is producing.
So technically, running your headlights might make you get worse mileage, or it definitely makes your engine work *slightly* harder.
^not an equal comparison to power draw of say an audio amplifier or headlights.
anyone with a big audio system has seen headlights dim and idle speed decrease a bit when the subs hit hard.
:devils advocate: So by that Theroy (which is technically correct) an MSD or other Ignition system shouldn't work either.
It creates more spark by amping up electricity, but you can't create more energy for free. So it has to pull it from the Alternator. But somehow somewhere along the line More energy, more horsepower and better fuel economy are the product.
(I'm sure there's some flaw in there somewhere, I'm no freaking engineer, and I didn't stay at a holiday inn express). But the general idea is in there..... somewhere...
Edit: they also said you could never sail from Europe East to the Indies...
What i am a skeptic of is being able to easily produce a sufficient amount of hydrogen on board your car to make this work.
My system is pulling right at 3amps. We shall see if it is worth it or not.
^Not sure if this is even on the same level as to what you guys are referring to but, I know certain Aircraft that injects water to increase power for take-off.
