Loganwayne
#BTL
- Feb 15, 2013
- Clyde, North Carolina
Towing with my 5.9 zj pulling my aluminum boat weights about 1600 lbs loaded down. It only squeaks when coasting goes away when under power or braking. I’ve checked the hitch to make sure all the bolts were tight, they were. Also I had to pick up 700 lbs of mortar today for work loaded in the zj and no sounds. I’m racking my brain trying to figure out what it causing the noise. Could it be the ball and trailer hitch squeaking if not enough freeze is between the two?
