Welding Helmet Recommendations
NickMaul
Norfolk, VA
Howdy crew,
After 4 years my $100 Hobart auto darkening welding mask is starting to fade away. Since the holidays are coming up I figure a new one would be a nice present to myself. The comfort of my current one is pretty awful and I would also like one with a grinding mode.
I weld mig and stick in a garage environment. I probably weld a handful of times a month but when I get a big project it could be a few hours strait in one sitting.
My budget cap would be $200. I have a handful of local welding shops in my area.
Any recommendations?
TIA :D
I love my 3m speedglas. Its the lower end model, 100v. Light weight and the head gear is comfortable. I use it for work and haven't had any problems in 2 years.
If you'll be using it for stick and mig I would recommend a variable shade helmet.
I don't weld a ton, but I got a Lincoln Viking 3350 for around $220 earlier this year. I don't have anything to compare it to, but it would likely fall into your budget if you look around.
Where did you find it at that price?
EBay, Jackson welding helmet. Around 30 bones.
I prefer the bottom one. Less glare. Good head gear. Light weight. Virtually nothing to fail. No interfering light on off. No bateries. Normally a good all around shade. Weld and grind one hood. Doesn't get scratched like a full face clear shield. Veiwing widow better protected. And best of all cheap. I got 15 plus years in one. Third head gear. Used 5 days a week. Sometimes 7:p.
I run the top. These last for ever.
I use a miller digital elite. Has 4 modes , grind ,weld, cutting and x mode . X mode is my favorite. Works off electromagnetic pulses instead of light which works great outdoors or when something is blocking the line of sight of the light sensors. I bought mine off line a few years ago for about $200. Remember it's just your eyes it's protecting, don't base your purchase online on price.
Jackson fixed shade with a 10/11 Hobart gold lens from tractor surprise.
Auto dark - I would buy the new lincoln with the true sight color. It’s a huge step forward and is very affordable.
I don’t like how the front lens on the sentinel gets beat up quick bc it’s so far outward from the helmet body itself
I also have the miller digital elite and freakin love it, until the batteries run out....then i have a harbor freight cheapy auto dark as backup that has served me for 6 years....with a handheld shield for when i cant fet in certain areas
Can you expand on this? Do auto darkening helmets have a gold lense or is that going to be for a helmet with a fixed lense.
Gold will be for a fixed shade, and the clarity is nice.
Fixed shade helmets have their place, but try flipping one down when you're elbow deep under a truck or in a tight spot.
Gotcha. There is a pretty large welding shop local to me. Comfort was a big factor here so I may go there and try some on.
The gold lense sounds like a good idea for stick welding because that is the hardest thing for me to see.
