What axles and size tires yall running
Y'all with the 8's and 40's what ratios are you running?
Im running the stock 4.10s
22re, propane, 4.7 case. Dual cases (with the 4.7s) waiting to go in.
I havent had any issues. It would suck without the 4.7s though thats for sure. I can get it up to speed in 2wd, but i wouldnt want to drive it very far (not that it could anyway).
35" boggers on beadlocks.
Dana 30 front/lockright
Dana 44 rear, welded.
Never been wheeled though, at least that I know of...:flipoff2:
11.00R-16 Michelin XZLs and/or 38x12.50-16.5 Swamper SXs
D60 w/ Lock Right & 14 bolt that's Detroit'd, stock 4.56s.
52" XMLs on stock 10 bolts locked and wheeled heavily with a 600hp nitrous motor...
Want some ocean front property
you could probably move up to 54 Boggers with no problem:flipoff2:
My TJ 35-1250-15 KM2s for the mall and 35 Creepy Crawlers for the rough stuff. Dana 30 (aussie locker) and Dana 44 with a spool. 4.56 all around.
F350 has 305-16 Terra Grapplers on D60 and Sterling axle
235/75 M/Ts on 15x7s
Dana 44 front and rear
Only three people running rockwells? I know bottomland4x4 and SSwaters run them but who else has a set of rocks?
60 front/14 bolt rear,2 detroits with 4:88's,38 boggers.I'm doin a 241/205 doubler right now and goin to 39 inch TSL's.
Why would anyone do that? Those are overkill.
on my trail rig xj i've got stock d30 and d35 running 38" bald swampers. have worked fine for almost a year now and has crazy clearance in the mud and on the rocks.
