What axles and size tires yall running
Thumper
Henderson
What size tires and kind of axles are everyone running?
40 Iroks on Toyota 8"s. 30 splines, cromo hubs, ARP studs all around, Aussie front, Spool rear. Never broken on the current setup.
the CJ has beadlocked 36" SXs for offroad, 35x12.5 BFG MTs for the mall. locked and built AMC20 and D30 axles with 4.10 gears.
the grocery getting XJ has 31x10.5 on the factory geared open 3.55 C8.25 and D30.
Towrig has P285R16 Dayton Timberline AT or something. I think its a D60/D70 combo, whatever the factor standard for 5spd 3/4-ton Cummins Ram got.
37" Xterrains on Ford HPD60 (lockrite) with 35 spline chromoly outers and a 14 bolt (detroit) in the rear.
40 inch IROKs on front HP44 and rear 9 inch.
52" XMLs on stock 10 bolts locked and wheeled heavily with a 600hp nitrous motor...
Want some ocean front property
I laughed, thank you I need to do that.:beer:
'83 Lux
stock 4.10's
welded rear
Marlin duals
VERY HOT running 22R
all stock shafts and outters
35's
Rear: toy 8" 35x14.50 boggers 4.10 gear lockright
Front: about to break the IFS 35x14.50 tsl sx 4.10 open
Next front: toy 8" same tires 4.10 gear lockright with spool in the rear.
Currently 35s on a D44 and Chrysler 9.25. Slowly gathering parts to swap in my 60 front 14b rear and some 44s.
Duane
was hp44 and 9" 3.55 with 44s tired of breaking axleshafts now its going back together with rockwells and 44s
I ran 37" Comp. Trepadors on a Toy 8" front and rear (rear was a Diamond housing though)... Stock shafts...ARBs.. and it was wheeled...
Damn, i was popping birfs in the backyard on 36s. Broke studs on 38s. Dont break anything now....yet.
Exo is not for looks(Slravene).Yes I currantly run Longs,5:29s,hydro-asst,duels,propane,etc.Do I wheel? River Rock,Wind Rock,Tellico,Harlan to name a few!
I never saw a picture of it. just going off the info that was posted i thought you were a nut. now i know you have some sense. good truck.
