Been dealing with low batteries in the crew for the last couple weeks, they finally gave up the ghost last week. One tested fine, just needed a good charge but the other was cooked. Picked up one new 34/78 Diehard at Advance; as much as I hate piece-mealing things, both of these are gonna be replaced before next winter with a set of AGMs.
Swapped in the new, cleaned and checked all my cables, turned the key and
Nothing.
Turns out, direct drive starters don't like trying to turn over a high-compression diesel engine with low voltage; who'da thunk it? I did an autopsy on the old Oreilly's reman, after 4 years of faithful service, I think me putting 24V to it trying to test it finished it off.
Spent some money. Got a new Powermaster gear reduction starter; these are the cat's ass for 6.5s and 6.2s, and I fully believe it!
Cleaned up all the ARP hardware before swapping it in,
Had to solder a new end on the ignition trigger wire, but once everything was put together all I had to do was tickle the key after one cycle on the glowplugs and it coughed to life with a big cloud of smoke after sitting stone dead for over a week!
Going to do an oil and fuel filter change tomorrow, then a wash and good solid interior cleaning on Sunday,
Brake lines all done, just need to bleed the system and see if the calipers and drum cylinders are any good.
Got the old 258 off the hoist it’s been dangling from for a few weeks and on to a stand.
Removed the “new” engine from the shipping cradle I built and now it’s on the hoist. Installed the flex plate and got everything ready to mount the transmission before having to call it a day. Also, pushed everything back to the side de of the garage. Sure is nice having the jeep on Dollie’s and everything else on wheels too.
Well shit.
Full service done, Amsoil 15W40 and EA filter, Wix fuel filter "cartridge" and greased it butthole to brisket.
Noticed a small dribble of diesel off the back of the motor but I assumed it was just some residual fuel that spilled when I was swapping filters.
Went to run some errands and realized something pretty quick.
It was in fact, not residual fuel trapped in the valley but a steady stream pouring out from the back of the motor. Spent about 30 minutes at the Salisbury 7/11 wadded up in the engine bay pulling the "fuel bowl" apart and checking all the lines; so if you stop in at the 7/11 and see the lake in front in front of the far set of diesel/gas pumps, I'm sorry that was me.
I'm not sure if it's the filter itself or if I tweaked a line; I'm pretty positive it's a return feed judging by how much spurts out when I shut the truck off.
Guess I'll be swapping to the AirDog much sooner than I anticipated.
Status update; tore the upper intake off Sunday evening and spent probably 3 hours cleaning all the garbage and leaked diesel I could get too; I really should've pulled the lower intake too but I don't have any replacement gaskets.
Noticed a few things that were pleasant surprises; the glow plug harness is an HD style and it's got an updated braided steel oil supply line for the turbo.
Got the fuel filter manager unbolted and checked the tank supply line, IP supply line, water separator gasket, anything I could think of and poked a couple generic o-rings that fit the fuel lines.
Got it all back together, and outside of a few little dribbles and the lift pump leaking internally I think I got it. Drove it to CLT yesterday morning for an interview and it did great tooling down I-85.
My wife asked why the window was duct taped up the other day so I figured I should make the new beater a little less beaterish. Drivers door outside handle was broke, internal latch mechanism was all busted and wired together, window regulator motor was toast and there was no door panel. It’s shocking how much people are asking for each of those parts on eBay. Found a guy with a complete door for $60 and hauled it home today. Swapped over all the guts and the door panel and she’s good to go now.
I hooked the trickle charger up to it, haven't driven the tacoma in like a month, and even then it was to get mulch from lowes. Thinking of getting out of the house and heading up to the mountains and drive down old nc 105 with my dog on Monday to look at some mountains and trees.
We rode old 105 a few months back and it was sad the destruction it saw from the hurricane. Still a nice easy ride but the trees that got destroyed were crazy. You could see areas where the wind made straight paths of damage.
I cussed it. I cussed it and I cussed it and cussed it!
First I cussed it because the automatic transmisssion wouldn’t mate to the crankshaft that had a manual pilot bushing/bearing in it.
Then I I cussed it when the bearing came out and bushing/spacer thing stayed in. Then I cussed it more each hole that drilled in it to get it loose until I finally got that out.
Then I cussed it again after test fitting TC to crank to make sure it fit and put it back on trans and it wouldn’t &@$?! Go and then I just stood around cussing before calling it a day.
So… productive and happy day in the shop. I think I’ll go to Disney now.
Sounds about right, but now that you’ve done it it’ll be easier to take it apart and reinstall it after you find out you missed something 🖕
