Sold mine for $100, and wish I didn't. I seen them as high as $300 but never sell, but I guess it depends a lot on the time of year also.How much is the under dash a/c system worth? I don't think mine will fit with a ford np435 because of the shifter location
Yes, how much?Are you guys speaking of the black plastic box that the defrost and duck work? If so I have one I would sale. ...
If I had a functioning a/c id take a torch and heat/bend the shifter to clear.How much is the under dash a/c system worth? I don't think mine will fit with a ford np435 because of the shifter location
I haven't put it in yet so that's the hope but after measuring it seems like the shifter tower will be less than an inch away without the lever. I could always do a 3" drop skid instead of a 2" and probably make it work.If I had a functioning a/c id take a torch and heat/bend the shifter to clear.
My a/c unit is a piece that connects to the underside of the dash. All the vents are housed in the one unit separate from the black box with the duct work and defrost.Are you guys speaking of the black plastic box that the defrost and duck work? If so I have one I would sale. ...
