Trixie the tracker
DirkaDirka875
Ima need 'bout tree fitty...
Bear Creek, NC
After alot of heckling from my buddy, i've finally decided to start my build thread. The project first started out as a 1989 geo tracker that my buddies got for me for my birthday some few years ago and after alot of money and alot of mistakes made, i ran across a 1999 geo tracker that only needed a fuel pump.
First trip to uwharrie
After awhile of wheeling it and having problems with the IFS, i decided to strip everything out of the '89 and put it on the '99. Plans are as of now to 4-link the rear, 3-link the front, run a toyota steering box for the high steer kit, install a samurai tcase with 6.5:1 gear, toyota axles welded front and rear, 35" TSL's, and 4 14" fox racing airshocks
Started Tearing it down
Cleaned up the framerails front and rear
And did what was necessary for all builds and sat the tires under it to get the look
Welded all the mounts and truss onto the rear axle
Welded on the upper and lower mounts for the 4-link
Fixed all the links and installed
Sat it down to check full bump and everything's looking good so far!
Big thanks to Stuntman autoworks and untchabl for all the help so far, long ways to go to make it to zuwharrie this year
It has the 2.0l in it, and got a little more work done on it tonight. Stuntman autoworks cleaned all the unnecessary brackets off the front axle while i mocked up how i'm going to mount the steering box.
looking good. Im guessing your tracker was rack & pinion before? I would sure love to have the 2.0l over my 8v anyday.
Yea it was man just glad that it seems like the steering is gonna work out. Ive been wondering if the stock power steering pump would have enough ass for the toyota steering box so i guess ill find out soon enough lol
Finished up plating the frame rail with 1/4" steel and mounted up the steering box
Went to Marsfab and had Chris bend me up some air shock hoops and cut all the tabs i need to hopefully get this rig on the trail! Big thanks to Chris for the awesome job he put into all the parts!
Tabs for the shock hoops
Tabs for the crossmember bushings
First ever produced "The Cats Ass" shock tabs
Big thanks again to Chris for cutting these out for me and to stuntman autoworks and untchabl for all the help so far. Oh and to Mrs. Stuntman for cooking us lunch as well
:D
Getting closer buddy, excited to see this one out on the trail. Going to be alot different wheeling it this year compared to how it was last year. LOL
