mbalbritton
- Mar 22, 2005
- Orlando, FL
I foresee Ice Breaking like on Deadliest Catch.
I dont work at a nuclear station..in which picture taking is prohibited. There not strict at coal fired plants.Im kinda surprised you're allowed to take pics inside the powerplant. Seems that would be national security issue.
No OSB or anything? yikes.
I'm guessing your house was probably built probably mid '06 to mid '07 when osb was $20 a sheet and contractors were using the fiber board between OSB corners.Our kitchen sink is on an outside wall and always freezes up if the temperatures gets down into the teens. I finally decided this past Sunday to figure out why. I thought maybe there was insulation missing. To my surprise, when I pulled the vinyl siding off, part of the wall was missing! I removed what was left of the fiber board and the ruined insulation, added pipe insulation, replaced the wall insulation, and installed OSB. Pipes did not freeze last night or this morning!!View attachment 112460
Close! It was built in 2005.I'm guessing your house was probably built probably mid '06 to mid '07 when osb was $20 a sheet and contractors were using the fiber board between OSB corners.
Bad thing is someone can kick the whole wall in easily.
Ha, my brother broke both door handles on a 80s Honda Accord back in highschool...it was a 2 door, I had to go in through the trunk.i didn't have pipes freeze or bust, but it did get cold enough that both rear door handles on the wife's accord broke when we tried to open them.
but luckily we had no ill effects. Thawed their pipes out and they had water, no leaks luckily.I check my power usage daily and it usually comes in around $7 a day. Last night was around $13
anal much??
I guess the pipe was just frozen somewhere, no flooding anywhere, water pressure is back to normal. Next time it gets super cold, I'll leave my bright halogen utitity light in the uninsulated closet where the water line comes in, that warms up the garage when I use it.hopefully no busted pipes, but this morning the water was only trickling in, I'm guessing frozen up internally. It was fine last night. It'd be nice if it warms up today and all is good.
