- Mar 24, 2005
- Stanley, NC
I've thought about it, but I just can't give up the granny gear.you decide to pull the NV4500 I wanna
Shit, that's more than what it seems it would be, mine must be closer to 5k with all the steel I run.@jeepinmatt
I just put my 04 TJ on a scale.
4,160 pounds.
4.0L 5 speed
1/2 tank of gas
No doors
Soft top
No carpet or back seat, front suspension seats
1/4" steel engine skid, tummy tuck and gas tank skid
Mix of currie & rokmen johnny joint short arms
Front & rear diff sliders
Aluminum wheels with 35" mtr/k, spare is tub mounted using an exogate
Stock axles
Aluminum front and rear bumpers with aluminum fairlead mount and winch deck
Warn 9.5ti winch with synthetic line
Aluminum front fenders, sliders and rear armor
Poly performance front half cage, no padding
4" coil springs 1.25" body lift
Should be able to get to 4,000 pounds by ditching the steel under armor for aluminum.
3,500 pounds is going to be tough to pull off.
@jeepinmatt
4,160 pounds.
4.0L 5 speed
1/2 tank of gas
No doors
Soft top
Stock axles
Dayterkerderjerrrrrbbs!!!^^^ they took our jerbs!![]()
Only if his posts are 5 sentences or less and actually make sense, so... no...Y'all don't read the John Fuller threads, do you?
gaudy bumpers with lightweight ones from Barnes4wd.
