Fabrik8
Overcomplicator
- May 27, 2015
- Huntersville
So we're getting our crawlspace encapsulated and a perimeter drain and sump installed. Why any of this hasn't be done since 1989 when the house was built, I'm not sure. We had the house only two years and I'm already aware that the crawlspace has been flooding when it rains a lot, but I digress....
The vents are being insulated and sealed, leaving behind the black plastic trim bezel around the brick curtain wall and also the diamond plastic screen and insect screen. The ugly bezel and screen no longer have a purpose, so I want to get rid of them.
There are vent covers out there, but they are either really ugly, or really expensive, or a combination of the two. I don't have to do this right away, because the sealing is already done and this is just a cosmetic finishing touch. I don't mind putting some time and effort into it, because we're slowly moving through the house and cosmetically upgrading most everything as we go along. The results will eventually be worth it.
Soooo.. Does anyone have good ideas for cosmetically blocking the vent cutouts in the brick crawlspace wall?
My ideas so far:
Any other ideas? Builders, architects, people with obsessive aesthetic tastes?
My ideas so far:
- Cut some flush/recessed panels out of something paintable (there are lots of choices).
- Make a mold and lay up some fiberglass pieces with a nice looking step flange (pretty easy, I used to do lots of composites work), then paint.
- Get a bead roller and make some metal panels with a step flange, then paint.
- Make an inlay panel out of brick veneer. Probably bond the veneer to a backer panel and then mortar, and seal to wall with a movement control joint using urethane or whatever. That's my favorite so far, if the brick color can be matched fairly closely.
- Patch the openings with concrete/mortar, then apply stone veneer over entire crawlspace wall. Design new garage skirtwall to match stone veneer.
