- Mar 13, 2005
- Raleigh, NC
So the pros tell me.
He wouldn't be much of a salesman if he said otherwise.
In Charlotte I buy from Green Resource.
Its about $45/ 50 lb bag. Certainly not half price of regular Pennington but much higher quality seed. So the pros tell me.
I suspect what @RobMcBee is talking about is the expensive ass patch repair stuff that is $40 for a 20/lb bag and is mostly shredded newspaper.
We recently just bought a house then was stripped to the base and rebuilt. In the process destroyed the lawn that the neighbors tell me was nonexistent anyway. Back in Oct they tilled, put down new soil and seeded. Cause of the warm Dec it grew in pretty well but they also put down straw which also took and prevented the grass from growing. In January when we closed I did some research to figure out where to start. Did the lime, gypsum etc. Beginning of March I raked up all the straw that was left and the grass has grown in decent since. My one issue is on the side of the house it gets soaked during the rain. Our driveway slopes down into our house so all that water gets pushed on the side as well as the gutters exit there from the front. I'm planned on doing a french drain but any ideas for drainage from the driveway? Or instead of growing grass there, since it's a high traffic area to get to backyard what else could I put there to help runoff? I was thinking maybe to dig up half foot of area where the lawn driveway meets, then digging down another half foot or so and put in some rock so the water goes under and drains naturally but not sure that'll work. Our soil is mostly clay that doesn't hold water anyway so it's an uphill battle for sure. The rest of the lawn is ok, it has its thin spots but I'll address them in the fall with aeration and over seeding.
The other thing I do plan on building a garage at some point but that may a yr or two. This area water stands and also drains the backyard which creates spots where grass won't go either. What do you guys think?
Sent from my SM-G900V using Tapatalk
Allegedly, shredded cypress mulch is supposed to last 3 yrs.
After 6mos, double shred and triple shred hardwood mulch need to be top dressed to keep the weeds down (and keep the beds from looking like shit).
Dunno if the thing about cypress mulch is true, but for the small bump in price/yd, I'm going to find out.
Great info, thanks for tips. Here's some pics of said flower bed if you wanna call it that. Won't get to that til after the wedding in August...Yep, like what's pictured below. You would only have ti cut a trench wide enough to fit the drain in and the fill in around it with concrete. You could then either tie your downspout in with the drain line or just direct it into the channel drain itself. I've seen a 4" channel drain take on a huge amount of water.
Another, cheaper alternative is to form a curb of some sorts to direct the water away from the foundation. It won't work nearly as well as a drain and you'd still have the issue of water in your side yard... So I'd skip this option unless funds were tight and you were just worried bout water on the foundation
Back on lawn, what do you guys suggest I do next as far as fertilizer? I've done Lesco fert/weed control but wondering what would be good for summer.
What do you guys with dogs do about their piss killing spots?!
Any idea how difficult a project like this is for a dude with no experience in concrete anything? I get some water in the carport. Not really much to worry about, but it pisses me off to stand in a puddle to get in my car when it's covered.
On that same line of thought, what's the process to move concrete sections of a driveway or walkway back to level? I've got two pretty bad portions of the driveway and front walk that are both an inch or so below the rest of the walk. I've seen a few companies that can do it, one looks decent out of Greensboro I think...Tarheel Basements or something like that? I'm not sure they will come down this far, or if the leveling system is even that good though.
There is two methods. One is to pump foam under the low parts and pump it back up to level and the other is to grind off the high areas to match the low areas. I don't have any reliab;le people to recommend for either. I've called both to come out for bids and neither have followed up.Any idea how difficult a project like this is for a dude with no experience in concrete anything? I get some water in the carport. Not really much to worry about, but it pisses me off to stand in a puddle to get in my car when it's covered.
View attachment 215419 THIS sprayer works like a champ! Glad I finally bought one.
Slab jacking does very well, but its expensive as hell and could sink again if you don't find out why it sank in the first place. As far as difficulty goes, I'd place it 3 out of 5. Hardest part is cutting the concrete and removing it. You need replace very little because the trench fills most of the hole.
There are at least three easy fixes for the concrete:
1. Ignore it.
2. Pour a topping slab over it. The topping slab will spall off eventually, but it might take years.
2. Pay somebody to demo the sunken area, rebuild the subgrade, and repour. If it's not a big area, this can be done fairly inexpensively.
And yeah, there's the jacking people, but that's expensive, and usually only employed on foundations and things like that.
As for the trench drain, if you have the means of scoring the concrete (circ saw with abrasive blade works and is cheap) and an air chisel, you can make quick work of putting a trench in a slab.
On a side note about the sprayer I bought the 21.5 gallon model and found out it runs out way quicker than I thought... I do have a large area I'm spraying and should of sprung for a larger unit. The 2.2 gal a min pump puts it down lol. I don't think I'll ever strap my backpack sprayer on again.There are at least three easy fixes for the concrete:
1. Ignore it.
I think one of those is in my future.
