Fabrik8
Overcomplicator
- May 27, 2015
- Huntersville
Lol wood is inconsistent. Log finish.com sells color match caulk. 1/4" will be fine as long as you use elastomeric caulk. Make sure it takes stain if you have future plans for a restain. CNC routing a board to match siding would be cool though.
Forget that noise. Actually, let me rephrase: I wish color matched caulk was my biggest issue right now.
The siding is painted, so all of this is getting painted, no color matching caulk required. I got light gray just to stand out less than bright white, even though it will eventually get painted over. I'm ready to prime the cedar mounting block... ...as soon as I have a cedar mounting block.
I think the gap will be at least 1/8", so maybe I'm good to go after a lot of glue-up. I wanted to make everything lower profile (instead of 3/4" board glued to bits of siding) but I think I'm done being picky until I have a better solution that actually works.
I hate being this anal, because it's all going to get replaced one day with different siding or whatever, but it has to be right until then. I'm doing all of my fitment experiments with the front porch light (also the biggest fixture), which doesn't see any direct water at all because of the porch. The other 4 fixtures are not so lucky, and need proper sealing.
Sadly, all the rest of the work will have to wait until the weekend, because now I have to spend my vacation day tomorrow cleaning the house for someone that I forgot I invited. That means putting away 600 tools that I don't have room for because I don't have the garage built yet.
I'm writing this from the kitchen while making apple sauce to de-stress.
