BigClay
Knower of useless ZJ things
- Sep 24, 2008
- Winston-Salem
So what are the advantages and disadvantages of tall skinny tires. Specifically 35x10 tires.
The only pro I have found with tall and skinny tires is the fact they clear stuff (frame, control arms, etc.) The major con I found was they are not stable at all when aired down. Not really a big fan of felling like my rig just wants to lay over and nap on minor off camber situations.
That's the aspect ratio of the sidewall width to sidewall height. You're going the wrong way with a skinny tire if you want a stiff sidewall or any sort of responsiveness on the street. You can actually help that a little bit by putting a skinny tire on a slightly wider wheel to get the sidewalls not parallel (making the sidewall into a tall trapezoid instead of tall rectangle), but that's not something to be done lightly at low pressures without beadlocks.
So let me throw this into the mix. I currently run my 33x12.5 TSLs on a 15x7 wheel, if I ran a 35x10 on a 15x8 wheel, wouldn't there really only be a 1" difference in tread contact?
I use 7.50x16s old schools and do just fine. Don't waste time with the military style ndt's for performance. They suck off road.Interested in this as well. I am really wanting to do some pizza cutters on the Willys for the look/cool factor as long as it doesn't have to big of an impact on performance.
Could be wrong but i wasn't aware of any sticky under 37 other than the short coarse tires?I like the 35x12.5 treps too, just more pricy than the comparable intercos. Not sure how much a d30 would like stickies either. Lol
Has anyone figured out a way to get these tires here?
I have been running Q78 (35.5-11.5-16) tsls for a while on a few different jeeps (mj d30 yj d30 then d44 zj d30) and I like them a lot, they work great in the wet, they put my buddies 42" tsls to shame at the SHOP when it was wet. I run mine at 6 to 4 psi depending on how I feel, they do make for a sloppy unstable feeling ride at low psi but I don't mind it so much, they do get short at that that psi, I have run them on two sets of 7" wheels and one set of 8" I can't tell much of a difference. They were fine on the road when they were fresh.
I would imagine since it's followed by "at low psi" he means off-camber on a trailIs the sloppy unstable feeling you refer to on the street or on the trail?
