YJJPWrangler
- Jul 19, 2005
- Charlotte
Got a little bit more done on the axles today. I popped the diff cover on the rear axle and about a gallon of water came out with the gear oil
. However the inside of the diff looked pretty good. I pulled both axle shafts and the 30spline shafts look very good. After talking it over with @MarsFab, I am most likely going to be running 4.56 Gears with a Eaton E-Locker in the rear and a Spartan up front. I am also going to convert the rear drums over to discs using Eldorado calipers and Chevy rotors.
I broke out the flap wheel and some wire cups and cleaned up the rear housing. Got it primered as well. Anybody have a good recommendation on paint that can hold up on the axles?
After that, I began working on the front. Now I have never worked on a front axle with hubs. I was able to get the caliper off pretty easily but was stuck with getting the rotor off. Big thanks to @rockcity for the helpful advice
. I was able to pull one entire hub/rotor off the drivers front. The bearings looked surprisingly well for its age. Everything was greased nicely and rotated smoothly. I am planning on installing either Warn or milemarker selectable hubs. I am planning on stripping the front, replacing balljoints, and replacing rotors/calipers etc.
More to come tomorrow...
. The cage will be removed and replaced with something that will allow a bigger backseat. The cage is stout as hell and I have no doubt that it served its purpose well, it just won't serve MY purpose. Everything else on the Willys looks solid and well-built.
. The original is in very bad shape. However, I am going to try and use the dash and the tailgate. I'm going to try and use the hood as well. As with most projects, this thing keeps evolving as the build progresses, which can be a good thing.
