Welp, I think my back is broke...
Had a friend over Friday night and we pulled the motor for better access to install the clutch, got the flywheel, clutch, and pressure plate installed and dropped the motor back in and called it a night. Had a busy day today. Met up with
@ghost and grabbed a set of XJ manual pedals from him. Thanks again and good to meet you! Got back home and started working on the transmission mating the bellhousing to it.
Used the engine hoist and dropped the transmission down through the floor. i did have to cut the rest of the tunnel for clearance. No worries, I have plenty of steel to build a new one. It took forever to get the motor and the trans at the right angle to fit correctly but it finally happened.
I decided I was a glutton for punishment and kept working. Got the D300 installed and tightened down. It was a pain in the ass to say the least. Theres not much room to work already and I'm trying to stuff 10lbs of crap in a 5lb sack
As you can see, I have a LOT of sheetmetal work in the coming weeks/months.
So couple things I have noticed. I might need to redo the skid plate/transfer case mount. The PO had a D18 and the mounting style is different. Currently the D300 is sitting on the skid plate. The current skid plate is stout but it hangs well below the frame so it might it get removed and a simple mount installed. This isn't that big of a deal currently...
Second, I think I need a new style of header
As you can see, the mounting holes for the slave cylinder put the slave smack dab in the collector. I really, really don't want to run the OE style exhaust as they are heavy as crap and don't look good. Ideally, I would like to find a header where the collector comes straight down almost in a Y shape. If anyone has a link/or one I would be forever grateful.
