marty79
the LS Swap Guy
- Nov 24, 2013
- Conover, NC
Hello to everyone!! Hope all are well and readying up for a new season of fun!! I really need some legit advise on this new house we moved into with the well pump/pressure tank/power consumption problem we are having so bare with me as I try and explain it in full details, Thank You very much for listening!!
Ok we are in a 3bd 2ba 1400sq ft roughly doublewide. 2 showers, 3sinks, washer, one outdoor spicket, and 2 toilets. Only me, wife and daughter and PLEASE understand first that I'm a huge power nazi!!
The Well pump turns on like all the time...flush a toilet, goes on>>wash hands goes on>>etc...sometimes cuts off within a min or two other times runs for 5-10min...other times doesn't kick on for a while where we have no pressure and then finally kicks on and runs forever till goes off.
Problem: Fluctuating Pressure and very abnormally high Power Bill!!(and I know how much power we are used to using and 202.00 for us is super high without using a electric furnace or bunch of A/C units)...
#1 all my life I've lived in houses with well water and I would never hear the pump run like this...EVER!! and when I would hear it it would take a shower or car washing of the swort to kick it on and still would not run like this thing does.
#2 I believe the 220v well pump is the culprit of high power bill due to it running so much everyday on and off and those long periods of runtime....besides the pressure varying during showers too.
Landlord says system is normal, power bill for his mom who lived here 30yrs was always like that and even 370s during summer with a/c window units running...WTH (we won't go into that)
From some online research, I've come to the conclusion that the pressure tank bladder thing has gone bad, or 2 the cut on switch going bad, or both causing the pump to cycle so much using lots more power!!???
**Also, the blue pressure tank in the well is 8gal (which supposively means only 3gal of water, rest air??) This also, (appears from research), to be too small a setup for this size house and water outlets which I've read will cause pump systems to run a lot more than normal.??? is this correct??
I'm sorry this is long, just trying to explain the situation fully and any and all help would be much appreciated as I'm smart enough to know something is wrong, my landlord disagrees, so I'm looking to figure things out on my own first then proceed with some factual information and even hire someone if need be to assess the system and it's performance or lack of. Thanks to all and blessings to all!!
so it's a gamble whether you'll save as much later from using them as you will on buying them
