moldman05
- Jan 27, 2006
- Rocky Mount NC
You will feel a bump and a sway. I can feel a belt breaking before it even goes flat. Or maybe your passenger will see the fender go flying in the air!
Youll know usually. Every one ive had went with a huge bang and jolt like I was rear-ended, followed by a vibration. Once I had the tread flap off the front right trailer tire and go under the right rear. It basically locked up both right trailer tires, it jerked the rear of the truck to the right and stopped pretty quick!Question
How can you tell when a trailer tire blows?
Oh you'll know...Question
Oh you'll know...
Question
Definitely this. People will look at you funny, but it only takes about 20-30 seconds to check everything once you're used to it.everytime I stop for food, bathroom or diesel, I do a walk-around. Make sure straps are tight, feel the trailer hubs and tires for excessive heat or tread separation.
You get a weird wiggle that you don't ever get any other time. Then you hear the shredded tire hitting the fender.
Pull over, jack up on the frame near the axle, swap tire, keep on trucking. Or you can get one of those drive up wedges that lift the opposing axle's tire enough to swap it.
I've experienced that as well, too many times...Mine usually sound like a shotgun going off.
But there are exceptions.
Sometimes you may not hear the boom as well depending on conditions or the volume at which @ckruzer has Taylor Swift blaring.
Own a battery operated 1/2” drive impact. Makes swapping blown trailer tires a breeze.
Thats me. I have a 4 way in every vehicle.I’m old school. I can spin a four way pretty fast and I’m pretty ocd about torquing lugnuts. Lol
I’m old school... and I’m pretty ocd about torquing lugnuts. Lol
I have a 1/2" ratchet in the driver's door pocket because it's only eight little bitty lug nuts.
You would be suprised how many people balls aren't rated for the weight they're pulling.
That shit's funny right there!No shit.
Thats a good point right there. A lot of the walmart special ball mounts or the fancy adjustable height ones are only rated to 5000 lbs. I have a solid forged ball mount rated to 20000 lbs and the 2 5/16" ball is rated 25000. The hitch on the truck is actually my weak link.I will add to make sure you use a ball and ball mount rated for the weight you're pulling. You would be suprised how many people use balls and mounts that aren't rated for the weight they're pulling.
That shit's funny right there!![]()
It must have killed you to watch me "brrrt brrrt brrrt" your in law's lugnuts when I rebuilt that 8.8.
#maybeididmaybeididntI'd just be careful on this method. I did the same thing, somehow got overzealous, and ended up popping myself in the mouth with the end of the 4-way while on the side of the road. Didn't really realize I did any damage til I felt my chin get wet. Went and looked in the mirror and saw I split my lower lip in three places.![]()
