- Mar 20, 2005
- Hendersonville, NC
I have a strap style yoke that'll work. It was my spare for my wife's ZJ. 1310 series D44a/D60.
$40 shipped and it's yours.
Ahh yeiiah U da man. Send me your PayPal again, thank you very much.I have a strap style yoke that'll work. It was my spare for my wife's ZJ. 1310 series D44a/D60.
Making little progress on the rear coil buckets
Dammit crap, In the zone and was looking through and I thought I read it right and somehow ended up doing this then the other steps. Well shishkabobs..I hope they're close enough then cause buckets and link mounting area is securedAgain John. Set it at ride height, build links first. THEN build coil buckets/mounts. If you place the coils in the wrong place on the axle you'll be removing them again.
Don't repeat an error from the front axle/suspension build.
Dang it I know, I get so ancy and going all the time I loose focus.Can we just call you “can’t get right”? Slow down and ask question if you need to. Don’t assume and just ask. There are plenty of people to help.
Sent from my iPhone using Tapatalk Pro
I did it or tried on the front but things got weird so I chose a route that kinda made sense from people's 3link posts.Not picking on you, but you said you did, so...
Did you really run the link numbers in the calculator? Cause if you did (like you said you did) then you'd already know the answer to your question.
Don't get me (us) wrong. We desire to help you learn. The proof of this is us collectively laying a ton of information in your lap. Down to the vehicle specific details and tips.
So, what are your link lengths, separation at axle and chassis? What is your anti-squat numbers?
There's more to a properly setup and acting triangulated 4 link than angled uppers.
Again, not bashing. Just wanting to see your own input based on the answers to questions you've already asked.
What few numbers I got from it I posted on previous page I think but it didn't help, I was lost so I just went with the true 3 link many were suggestingDid you really run the link numbers in the calculator?
Triangulate your lowers, parallel lowers will have quite a bit of rear steer. Plus it can help keep your roll axis in check.Dang it I know, I get so ancy and going all the time I loose focus.
So just making sure this is what I'm shooting for right
Well I typed in the numbers I have written down already so here's what I've got so far..only thing left is to set the rear exactly where it goes and measure upper links
I’ll share, but I fear this will be lost like triangulation.
There is no perfect setup, only ideal #s to shoot for, but you will always have to compromise to fit your chassis constraints.
Rear Antisquat less than 60-80%, less than 10% increase at full droop.
Front Antisquat/antidive less than 50%.
Less than 6 degrees pinion change.
Driveshaft style also affects this. If double cardan you want to keep pinion point at tcase output. If single joint shaft, then you want pinion to stay parallel to tcase output.
Front roll center height higher than rear.
Roll moments as short as possible. This means getting the roll centers as close to the Center of gravity height as possible.
Shoot for your top bell housing bolt for COG height.
Minimal pinion angle change and caster change in front.
Links as flat as possible.
40 degrees of triangulation in the links when viewed from above if no panhard.
If panhard, locate in front to reduce bump steer. Parallel and equal length to drag link.
Lower links equal in length to tire size. Vertical separation of links at axle 1/4 of tire size. Upper links 65-75% of lower link length.
I can answer why to any of these, but it gets very wordy.
Get the best you can. For where/how I see you wheeling, the most important thing is to limit rear AS increase in droop.
Getting the AS wrong will lead to wheel hop. Can be in front or rear.
It will ride better with flatter links.
Make upper chassis side mounts adjustable with as many holes as possible. Typically with 1” spacing difference vertically on holes so you can try different setups to see what you like the best.
You might also want to take a look at your masses. You're saying there that you have only 1500 total sprung mass on a 4800 lb. rig? That's a bottom-heavy b**ch. I like some junk in da trunk, butt damn, Gina!
I also doubt the cog is 28". I'd bet its closer to 60" with all that cage.You might also want to take a look at your masses. You're saying there that you have only 1500 total sprung mass on a 4800 lb. rig? That's a bottom-heavy b**ch. I like some junk in da trunk, butt damn, Gina!
Wow... I seriously need to go get my eyes checked... good catch.????
That says unsprung in the calc.![]()
In all seriousness, @RHSCTJ is right. The COG is likely much higher than 28" here. I'd be willing to help calculate it for you, if you would like. It would take a boatload of measurements from your cage, though. That, and I would be willing to bet that even at ride height the standard "top bell housing bolt" measurement is higher than 28". (I'm rounding off here from 27.68 - I did read this time...I also doubt the cog is 28". I'd bet its closer to 60" with all that cage.
)I also doubt the cog is 28". I'd bet its closer to 60" with all that cage.
For the front, make sure the truss and upper link mounts on both ends can't be yanked off with a bulldozer. The last thing you want to happen deep into a hardcore trail is to have your front axle rotate forward or backward 90 degrees, ripping off your shocks, coils springs, and bending your steering.
