marty79
- Dec 2, 2015
- Newton, NC
Hey I'm redoing front end and this came with ball joints..what is it (that funky but thingy) . thank you
I wasn't aware that these were special ball joints. These went in nice ad tight like supposed to.It's worth noting that you should only be using "problem solver" joints if you need problem solver joints. Once you use them once, you have to always use them, and may have to tack future ball joints in the sockets to keep them from moving.
Ok that's what I was referring to. Thank youyour referring to the threaded sleeve, that's for a d44 which uses the same ball joint.
Hahahait's a ball joint.
Yeah, it's because they're oversized and opened up the bores when you pressed them in.I wasn't aware that these were special ball joints. These went in nice ad tight like supposed to.
ok, how can you tell these are "problem solvers?" just trying to learn here, especially for future use like you mentioned. ThanksYeah, it's because they're oversized and opened up the bores when you pressed them in.
wait what...I'm confused?? I thought they all have the grooves in themThe knurling...
LOL i gotchaBtw those “grooves” are called knurling if you haven’t noticed.
uhhhh ok that sounds a little tedious, I'm paranoid now lol.That threaded sleeve isn't what everybody posted....
It is the insert that goes into the knuckle to set the working height of the upper and lower ball joint.
Press both joints in.
Use torq wrench to tighten lower nut.
Use speacialty socket to tighten special insert.( the funny thing you mentioned)
Then and only then tighten upper castle nut to spec.
Here's the socket.
And no. It does not set any steering angles. It's not a twin I beam.
It's also concentric.
This should help.
thank you very much btwLook at the procedure on the buletin. A quick Google got me that.....there is a right way.
Re-read my post. Look at the torq specs on the sheet..
You'll get it.
this actually makes sense, I've been looking into the D30 install for last 20min and I'm not finding anything on using that special nut with the 30, so I guess I'm ok then. thank you I've been kinda frustrated not finding any videos using it on D30 and thought all these years I was shown wrong and then doing it wrongThe adjusting sleeve is used in D44 axles like pre-80 Fords. I've never seen them used on D30s. On the Ford, the ball joint presses into the knuckle and gets bolted to the yoke of the axle housing. The threaded adjuster goes into the upper to adjust the preload.
ha ha of course, but I've never had that little funky special nut in any of mine. I've also always bought cheapo parts store so this is the first time buying some good brand ball joints maybe that's whyI use a piece of tube to drive the lower up into the C and a larger piece to drive the upper down into the C. Generous amounts of anti seize FTW. It's not rocket science.
Have you never replaced ball joints on a D30 before? Not flaming, but with all of the XJs you've rebuilt over the years, I assumed you had. Just seemed weird.
