marty79
the LS Swap Guy
- Nov 24, 2013
- Conover, NC
hey guys, need a little help. I've been reading too much stuff and just can't make up my mind on this:
Got a 16ft camper trailer ($100) with a single 6 Lug brake drop axle, 15" rims. The axle is centered on it, has brakes, 6 leaf springs mounted as a underslung drop axle..it's the square tube type bent all in one not welded or anything.
So I'm getting another axle to mount to it for dual axle car trailer and I know I need to also mount it underslung also but my question is this:
The 5 Lug trailer axle like most, has only 3 leaf springs so how will this affect the mounting and ride? Do I need to compensate for this and mount the spring hanger on this axle little lower?
Do I mount the 6 leaf pack axle in the front or the back?
Maybe I'm overthinking it as usual but I only want to do it once so here I am. Thanks for the help
oh wait...I've seen me do it too). You'd have to have at least one spare in each lug pattern. Now things are getting out of hand, right? You should just get a pair of matched axles, then set the suspension up properly for the intended use.
