BigClay
Knower of useless ZJ things
- Sep 24, 2008
- Winston-Salem
I believe I will need to get a 2" spacer for he rear of a dually to get 285/70/17s to fit. Will this size tire fit on stock 17x6 3rd generation dodge dually wheels?
2" you won't have to cut the studs but I think an 1.5 should make it clear.
I had 265/70 17 on my flatbed, they seemed to fit the wheels fine and only took a 1/4" spacer to fit. I think 285s would be fine but I don't think it would tale 2" of spacer to work. How much weight do you tow?
I'd make sure whatever you got was a very good spacer then. That will be alot of weight on the outside studs that will no longer be hub centric due to the spacer being used.Fully loaded there will be about 8k on the drive axle and 18k total rolling (bed camper and trailer with jeep). I was thinking 2" for ease of not trimming lug studs and to make sure there will be no chance of rubbing fully loaded.
From what I have read, the cheap ones are scary, but as long as it is a quality aluminum, they can be just as strong as steel. Any thoughts on that?
I'd use steel. It's not worth the chance.From what I have read, the cheap ones are scary, but as long as it is a quality aluminum, they can be just as strong as steel. Any thoughts on that?
I also foud these steel spacers https://www.wheeladapter.com/dually-wheel-spacers
That's the ones I used. The hub centricI also foud these steel spacers https://www.wheeladapter.com/dually-wheel-spacers
And Bora was what I was after when I found the Stahl. If it were my dually I would likely have gone Bora but with the potential loads of the dumptruck I felt steel was saferStahl is the steel version of Bora, if anyone is wondering.
Yes - this statement defies physics (chemistry?). There is no set of physics in which aluminum is as strong as steel.as long as it is a quality aluminum, they can be just as strong as steel. Any thoughts on that?
It also will help with limiting corrosion.Steel it is. Besides the above, I am going with steel wheels, so it will just be easier to keep the metals all the same.
So back to wheel size, are 17x6s going to be ok for the 285/17/17s?
Ask the tire place mounting your tires, they're ones making that decision for you.
I kind of need to know before I buy six new wheels haha
Common 7075-T6 aluminum has higher shear, tensile, and yield strength than common 1018 steel.Yes - this statement defies physics (chemistry?). There is no set of physics in which aluminum is as strong as steel.
(Unless it is poorly tempered steel etc...)
