RatLabGuy
- May 18, 2005
- Churchville, MD
Like that time we crashed a wedding in Harlan... @Loganwayne @McCracken @ckruzer @shagy9888
No joke, it's actually more effective that way but nobody does it because of ground clearance.
Yep. Steel does better in tension than compression because it can buckle under compression. Thats why they make cables out of steel and pillars out of concrete. When you're talking about plate steel and a 1-2ft span, you will get a measurable (tens of thousandths of an inch) of deflection, which is what you're trying to avoid. A properly designed and gussetted truss will be more effective, but no one mass produces those as far as I've seen. The old Con-Ferr under the axle threaded rod trusses we're possibly more effective from a design standpoint.
I copied this design for an old Ford axle......everybody laughed. I laughed too. I personally don't like the anvil look of most built axles.....but haven't found a approach that seems any better. The look and strength I want by design me thinks would be unobtainium.Yep. Steel does better in tension than compression because it can buckle under compression. Thats why they make cables out of steel and pillars out of concrete. When you're talking about plate steel and a 1-2ft span, you will get a measurable (tens of thousandths of an inch) of deflection, which is what you're trying to avoid. A properly designed and gussetted truss will be more effective, but no one mass produces those as far as I've seen. The old Con-Ferr under the axle threaded rod trusses we're possibly more effective from a design standpoint.
Those Con-Ferr axle "trusses" were about as close as you could get to being entirely in tensionCan you make a truss loaded in pure tension like you can a cable? Probably not.![]()
I just recently stopped this habit. I finally decided with a salvage title, 300k miles, leaking head gasket, and destroyed interior, it was time.
