- Mar 20, 2005
- Morganton NC
Workshop, garage, tool shed, or what ever is home to your tools, what ever is your work space?
I need to do a lot of organizing and cleaning up after this next run of projects I can’t get done right now. Need to create some long term axle storage, material rack, and organize my crap a whole lot more. Definitely need to pick up some more lights.
If you were up this way, Rural King has the 5500 lumen lights on sale for $18 and some change.
two step ladders, and some good boards, and a light weight friend, you can make it happen.Yeah I figured I’ll need 4 more to complete the garage. Gonna be weird making them work with the overhead lights with my Jeep in the middle of the garage.
If you were up this way, Rural King has the 5500 lumen lights on sale for $18 and some change.[/QUOTE
Horrible Freight has them for $19.--, when on sale. They even have a double bulb, but it double the price. That 5000, is Bright! I tried one in the basement/shop. Just bought another, to put in the attic, just in case i have to go there!
Got this made up over the weekend. 1/2" birch plywood. 10degree top for the batteries. It will eventually be mounted on a big french cleat system
@upnover ...French cleats are extremely easy to build with or without a table saw. Take a 5" wide board and rip it in half at a 45 degree angle. You now have a french cleat. One side of the 45 faces up on the wall and the other is mounted down on whatever you want to hang. If you have a skilsaw, you can build them.
@tlucier go right ahead! I've copied mine and added some different dimensions to fit what I have. Each drill slot is spaced 5" apart(center of drill to center). I can get you the exact measurements if you want. The battery tray has a 10 degree angle on the uprights for it(cut on a miter saw). Has enough room behind the drills to hold stuff I don't normally use or loose stuff(odd drill bits etc.) Put it together with brad nails and wood glue. I'm pretty sure I built it out of a single sheet of 2'x4' birch plywood 1/2. About $18 or so at Lowes.
... a big french cleat
Told ya to go with the 90”"I look so small in your arms"
65" is tiny in here
Looked massive in the exploder
