StretchASU
Playing country music til Troy's ears bleed.
- Oct 17, 2006
- Claudville, VA
@StretchASU Since y'all are on steering.....does the Astro set up go in the factory spot?
@drkelly. You obviously moved yours. Why not the astro route?
Looking at pros and cons for each. I will be running my Reid high stear stuff. Most likely 3 link. Not four link since I'm ditching the full hydro. Unless I go parrallel four link with a panhard bar.....that's a lot to package.
Edit: I don't think you lost much structure with the winch tray. Especially if you have a rear lip turned up or down.
Mine I’m pretty sure is in the stock spot. With the pitman arm that’s on it, it swings below the springs since the PO ran a Y link style steering setup on his Superduty axles. I’m still undecided on doing that or switching to a flat arm, with the arm end of the drag link mounted to the top of the arm. TBD. That’s my next project to tackle once the rear end is on its own weight. I’m leaning toward a different pitman arm and going full high steer since my axles have arms on them already and I would like the clearance.
These are probably my favorite types of jeeps to work on and modify. I'm digging the front and rear custom crossmembers with the 8274 the best winch ever made.
That front crossmember/winch plate/bumper is beefy and badass. I like the way it lowers the winch and is also a shackle spring mount. Good work man!
