BrianGreen
SSG Brian Green
- Apr 5, 2008
- Kings Mountain
Confirmed w/ the county, size can be 1/2 of "habitable space" which my full size basement counts. Hieght is capped at the aeverage height of the home as masured from several points around it to the apex of the roof (I couldn't sweet talk her into saying the chimney) so I have a cap about 18'. Grrr not ideal but workable.
What I'm thinking about at the moment is a 30x40 with the trusses running the shorter distance, 14' walls and a 12/3 pitch, which would be just at the max height at apex.
3 garage doors along the 40' span offset to the right so there is some un-doored space on left. Man door on left wall perpendicular to garage doors.
Inside, I'd like to frame it so there is a loft over the left most garage space, going full depth and maybe 16-20' (depending how that works out with the doors). So basically 2 bays are open high bay other is not. The back 8-10' of teh first bay (w/ teh ceiling) will be bathroom, 2nd bay will be shop bench space, and 3rd will remain open w/ just shelves at in the end so it is a nice deep space for a long vehicle. Lift in that one.
The magic to keeping that upstairs bit usable will be the trusses. If it's wood frame, that seems like a challenge - what kind of options to I have? How much space do vaulted scissors use? This is where metal framing seems ideal. But again, I don't understand how you connect interior framing to the exterior w/ that.
Looked into that. Specced out the price is in the same ballpark as a pole barn kit from IDYPoleBarns.com.
How do you attach it to the slab? Just concrete anchors? You feel like the construction is sturdy? Did you frame the inside?
EDIT - just noticed the Versatube has a horizontal cross-ties on the struss supports. That would be a problem for my upstairs section.
concrete anchors. I ordered mine with the rib spacing 4’ on center. I put 3/4” T&G subfloor on the walls. Predrilled and ran metal screws every 12” direct to the ribs. Zero regrets.
