Fabrik8
Overcomplicator
- May 27, 2015
- Huntersville
How much can that baby lift?
It says 75 TON CAP on the front frame.
You’re going to be impressed by what that thing can do. It’s likely able to be remote controlled not only the crane functions but traveling as well (low speed) where you see the red and white vertical stripe is the separation where the rear can extend back as a counter balance probably about 5ish feet, there can also be added weight plates on top as well. I’ve been trying to get one of my customers into a similar rig only has a forklift mast and forks would replace two 50yo machines that are difficult to find parts for.View attachment 336258
We hired out a Small cherry picker. Gonna be a few long days this week.
Looks nice! Did you freehand that or do you have an Alaska mill or something?Made some benches at the pistol range/ camp area
Thank you, they were freehand.Looks nice! Did you freehand that or do you have an Alaska mill or something?
We are changing some bearings.That's a neat little rig. I've never seen an indoor crane like that. Last time we had to move a big piece of equipment, we brought an outside crane inside. That little rig would have worked a lot better!
75 ton.How much can that baby lift?
Everything but the remote applies. They supplied one rigger and a operator. So far only one guy has done much. Not the rigger....You’re going to be impressed by what that thing can do. It’s likely able to be remote controlled not only the crane functions but traveling as well (low speed) where you see the red and white vertical stripe is the separation where the rear can extend back as a counter balance probably about 5ish feet, there can also be added weight plates on top as well. I’ve been trying to get one of my customers into a similar rig only has a forklift mast and forks would replace two 50yo machines that are difficult to find parts for.
rigger....
75 ton.
A lotYou know how much an hour that thing rents for?
And factor travel and cartage to get it there and backA lot
$100 delivery/ $100 pickup from herc last time I got a boom lift. Edwards charges a lot more than that just to drive from spring hopeAnd factor travel and cartage to get it there and back
pretty sure Edwards won't let you be the guy operating the rig once on site either...$100 delivery/ $100 pickup from herc last time I got a boom lift. Edwards charges a lot more than that just to drive from spring hope![]()
That looks like a fun time. What brand bearings do y’all use? We’ve had really good luck out of Dodge with good regular greasing.View attachment 336351
View attachment 336352View attachment 336353
We stopped here. 6 thirty am to 8 thirty pm.
A bearing inside this fly wheel was the whole reason.....it's also froze to this shaft.
I'll have to look. First time I've ever done this to this machine.That looks like a fun time. What brand bearings do y’all use? We’ve had really good luck out of Dodge with good regular greasing.
I gotcha. That’s an interesting piece of equipment. Shear or press of some kind?I'll have to look. First time I've ever done this to this machine.
Mechanical press.I gotcha. That’s an interesting piece of equipment. Shear or press of some kind?
