Never used one, but the Stihl RDR (Rapid Duro Rescue) chain has a different grind on them so they are more durable so firemen can cut through nails and steel stuff embedded in walls/roofs in houses, but it makes them slower in wood. A typical sharp edge profile would probably chip away pretty quickly when slapping into steel.anyone use carbide tipped chains? Bought one for my stihl 361 and it seems to cut pretty dang slow. Got it from forester shop
Don't even think about the 170. They are better than a hand saw, but you will be disappointed. Also, don't judge a saw by the name. Husky makes saws that can run with your MS460. With that said, if you like the feel of the 460, look for an older Stihl 028 Super. If the vibration of the 460 gets to you, find an MS261. I've owned both and like both for different reasons. The 261 is smoother, lighter, and uses less fuel, but doesn't have the solid feel of the old saws. The 028 is a late 80's/early 90's design that can be had cheap and will run forever, just like the 046/MS460. You can pick up an MS261 for around $400 used or just under $600 new, and you should be able to find 028's for about $200-250 used.Ok so update. I've dropped 3 more pines which basically paid for my saw. Woo Hoo! Now I like my Husqi but she does not have the balls of the big ole Stihl. Looking for something for small stuff. Stumbled across a few near me on FBMP:
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.www.facebook.com
Log into Facebook
Log into Facebook
All same seller. Thoughts?
I mainly wnat something smaller and lighter so I can keep the 32' bar on my hoss and cut and limb with a lighter smaller saw. Was considering the MS250 that I posted.Don't even think about the 170. They are better than a hand saw, but you will be disappointed. Also, don't judge a saw by the name. Husky makes saws that can run with your MS460. With that said, if you like the feel of the 460, look for an older Stihl 028 Super. If the vibration of the 460 gets to you, find an MS261. I've owned both and like both for different reasons. The 261 is smoother, lighter, and uses less fuel, but doesn't have the solid feel of the old saws. The 028 is a late 80's/early 90's design that can be had cheap and will run forever, just like the 046/MS460. You can pick up an MS261 for around $400 used or just under $600 new, and you should be able to find 028's for about $200-250 used.
The even numbered saws are "pro" saws and will last longer and have more power than the odd numbered saws.I mainly wnat something smaller and lighter so I can keep the 32' bar on my hoss and cut and limb with a lighter smaller saw. Was considering the MS250 that I posted.
Just borrow my 261About to get a tree dropped in the yard and going to need to saw them up for wood (and for a trials course for trials bikes).
What is a good saw that isn't stupid expensive? It won't be for heavy use at all just. Rather not buy used since dealing with people on marketplace sucks. Ideally trying to spend ~300 if possible.
Ok this is the info I was trying to understand. I figured there was a difference when I read the MS250 was a homeowner saw. Ok so I need to look for a 026/260/261 I think.The even numbered saws are "pro" saws and will last longer and have more power than the odd numbered saws.
Even ones being:
026/260/261
028/280
032
034
etc
Odd being:
MS170
MS250
MS290/291
MS310
etc
For the newer saws, its the middle digit. You truly get what you pay for in this realm. An MS261 will run circles around an MS290 and still be lighter. Search MS261 vs MS291 and read for hours if you'd like.
This might take a while. The one where we park the rv has to come down. (Not taking this one down myself obviously)Just borrow my 261
Move RV put a line on it cut it down. Or is the tree taller than the RV long?This might take a while. The one where we park the rv has to come down. (Not taking this one down myself obviously)
Way taller than the rv is. If it was only that big i would take it down myself. It’s probably 100 foot and a split trunk. Tall enough to hit my house or garage if it came down. Or my neighbors fence.Move RV put a line on it cut it down. Or is the tree taller than the RV long?
Then buy your own. When I got the 261, I wanted a Husky. I liked it more, but it was expensive. It seems like the shops around here are geared toward Stihl and push it more. Either will probably be fine. One place tried to talk me into a Dolmar, but it seemed both heavier and less sturdy than the Husky or Stihl.This might take a while. The one where we park the rv has to come down. (Not taking this one down myself obviously)
Dolmar makes a really good saw too. But Dolmar and Husqvarna use 13mm bar nuts, and Stihl uses 19mm, and I don't wanna have to carry 2 screnches, so I just keep buying Stihls (yes, I know they make screnches with bothThen buy your own. When I got the 261, I wanted a Husky. I liked it more, but it was expensive. It seems like the shops around here are geared toward Stihl and push it more. Either will probably be fine. One place tried to talk me into a Dolmar, but it seemed both heavier and less sturdy than the Husky or Stihl.
).That's on my list in a couple years when they are $700 used.Just get a stihl 500i. It’s lighter than the 462 and has Power close to a 661. It’s pretty much the only ground saw I use anymore. View attachment 347161
That looks expensive. Like cheap jeep expensive....Just get a stihl 500i. It’s lighter than the 462 and has Power close to a 661. It’s pretty much the only ground saw I use anymore. View attachment 347161
