Croatan_Kid
How's your hammer hangin'?
- Nov 4, 2007
- New Bern
Since you brought it up...
Unpopular opinion...BTR makes garbage. Especially "his" valve springs.
What about an intake and throttle body change is unreliable or hard to find parts for? The intake is literally a factory part. It's got longer runners to make more torque. Why go through the trouble of putting a well rounded, high compression motor together just to choke it off with the intake or some headers that are too small? It's not about peak power, it's that overall power. Power under the curve. Usable power.
I didn't list off anything ridiculous. The majority of the things I suggested replacing were for...wait for it...reliability. I gave him a pretty simple list of things to make good power that'll last so he only has to spend his money once.
To replace the factory valve springs with aftermarket, you need spring seats for install height. The factory valve stem seal IS the spring seat, those get replaced. Spring retainer locks are cheap. Might as well. Why would you not replace the oil pump, timing set, or push rods? He's never run the motor...they're unknowns. Also see: unreliable.
