maddog411
- Mar 22, 2005
- Harrisburg, NC
Hey SSWaters, have you finished your rockwell wheel brakes? Care to post up pics/specs on the calipers/brackets you used? Thanks!!
AgriSupply?I couldn't find something like this doing a search on their site, which admittedly sucks. Anyone have a part #, or a good photo, or something I can use when I go?
if u think about it u actually get way more braking force when u use pinion brakes because u are braking on the other side of the gear reduction. u get 6.72 times more braking force . so with only one pinoin brake u will get better braking than with 2 wheel mounted brakesbesides what's been mentioned, brake fade is a huge issue also. the rotor is spinning 6.72 times faster than a wheel mounted brake, and has half the surface area (1 pinion rotor vs. two wheel rotors). you'd also have to run drive flanges on the front to maintain front axle braking, which would be a pita on the street with a locker.
max tire size on a rockwell depends on how you drive, terrain, etc. just like anything else. the majority of people will have a hard time breaking one with anything less than a 48 michelin/49 irok.
Speaking of which, are they available locally? I know the stockers are...dumb question, but dollar for dollar, what is the biggest reason folks are building 60s instead of these if they are that much stronger stock?
Sam H
Not sure if this is too much to ask, but does anybody have info on the 5 tons? I can get my hands on two 5 ton rears, but I have no clue about the front steering 5 ton. They are 10 lug, 5:86 gearing, have a Detroit in them.
Thay should have 654 gearing. Unless somebody has come out with aftermarket gears. And a fully dressed 5 ton weighs right at a thousand.Not sure if this is too much to ask, but does anybody have info on the 5 tons? I can get my hands on two 5 ton rears, but I have no clue about the front steering 5 ton. They are 10 lug, 5:86 gearing, have a Detroit in them.
Wilwood Rotors 160-2894 LH & 160-2895 RH around $50 each.
(USA6X6 says use the 160-3870 &160-3871 $85 each, was told no real difference on a low speed application like this since I'm not doing any road racing)
Right now I'm using a Corvette master cylinder, don't remember the bore.
