skyhighZJ
- May 31, 2012
- Aberdeen, NC.
Drive up to Burlington and met @k5-1402 and gave him some doll hairs! This, is, cool! View attachment 350955
36x13.50 bias and on the raclines they are right at 35.5 at 20 psiWhat size tire and what does it actually measure
They use a smaller acorn nut. The kind that use a adapter. I bought mine at Oreilly auto last week. 41$ for a 20 pack with the adapter. M12x1.50Houston, we have a problem. Got home and needed to see newly mounted Irok/raceline on the truck. Ugga-Dugga the old one off. Slide the new setup on the hub and….. the studs are WAY too short. So,
A.) new wheel studs? (Which men’s tearing the whole hub apart (sad face))
B.) buy wheel spacers ( I need em anyway cause even the old tires get into the springs at full turning lock) and hope those studs are long enough to allow the RL rims to work. Guess I hadn’t paid attention but the centers where the stud/lug nuts are of the RL are SUPER thick/beef.
Suggestions?
I’ll have to check into that. When I put the rim onto the truck the studs barely even come out to the end of the lug holes on the rim.They use a smaller acorn nut. The kind that use a adapter. I bought mine at Oreilly auto last week. 41$ for a 20 pack with the adapter. M12x1.50
Hmmm. Are you running solid axle outters or Ifs outters? Not sure if the the stud length would change or not with either. I have always run with Ifs outters for the extra width.I’ll have to check into that. When I put the rim onto the truck the studs barely even come out to the end of the lug holes on the rim.
It’s a mini truck axle (79-84.5) I didn’t upgrade the outters cause I’m cheap and things were in good shape.Hmmm. Are you running solid axle outters or Ifs outters? Not sure if the the stud length would change or not with either. I have always run with Ifs outters for the extra width.
@marty79 can add that to his listPainted, installed, and no more ratchet straps! Time to measure for drive shafts. Oh, and find the u-bolts I need to clamp down the back mounting locations of the crossmember. When you run a newer 5spd in a 1st gen truck you slide the x-member back to the rear bolt location and use u-bolts to hold the rear bolt holes in place around the frame (per Bud Built). One would think that newer 5spd swaps are so common someone would make a fitting xmember but they don’t. Oh yeah, finish the exhaust too. Lol View attachment 356544
Edit: ordered the u bolts off the line. $25.00 to the door with washers and the proper ubolt Nutz.
He would make a killing. As long as he can press form the flat plate. Shit. I’ll send all the dimensions or even drag my junk down there so he can take his own measurements. It wouldn’t be hard.@marty79 can add that to his list
