gslander
- Aug 13, 2021
- Hickory, NC
2025 edit, build philosophy and goals:
I decided to add my build parameters to the first page of this, mainly to keep me grounded and to lay the ground work of why I did what I did. This truck needs to do a few core functions:
1) I don't have a trailer nor do I want a trailer, so comfortable to drive me and all my stuff at 70mph for hours on end
2) wheel whatever I want within reason, I have no desire for death climbs or hill killing
3) be reliable and simple
4) have easy to source parts
5) double as a truck doing truck things
So laying that out here is how I have worked within those parameters:
1) the truck is geared low, 5.29s on 37s with a V6, 5spd, has a full interior, working AC and cruise control. I even retrofitted power seats out of a Camry into this thing. Pretty much every wheeling trip is a mini UA for me.
2) I enjoy rock crawling and not hill killing. It seems here in the SE there's a big delta between trails that can be done on 37s and a full bodied rig, to bouncer shit. Even in a buggy I have no desire for the bouncer shit. I have no desire to play on things like cream puff at Harlan and little Caesars at AOP for example
3) the truck is on 37s with leafs f/r for a reason, one because I'm cheap, but two because leafs do a ton of things pretty well in one package, are hard to break and if I break a shock I can still get it home. Same with mechanical lockers f/r and the same drop out diff f/r which has saved me once already.
4) this is getting harder to do with a Tacoma based platform, especially for after market parts, but I can kind of manage with this. For some reason auto parts store treat these trucks like a 911.
5) I still need to haul shit with this truck. That's why it has a full bed, I also think bobbed Toyota beds are ugly, but mainly I need to carry stuff. I have explored a tube bed but come up with nothing but overcomplicating a factory bed with nothing but negatives and compromises.
I have a v6 5spd 2002 tacoma that I have and been building since 2005, I'll skip all the bolt on IFS on 33s stage of the build and post up the cool shit. The truck as of today has 37s, fj80 rear axle with a spartan, flipped fj60front with an Aussie locker, rcvs/longs 5.29s and is on leafs. It was all built in a suburban 2 car garage with a grinder, chop saw, 115v welder and no other special tools.
I built a lefty and dual combo in 2010 a few years after blowing up my taco box I built in front of the stock chain drive tacoma case. It's stuffed with 30spline marlin chromo shafts and some og 4.7:1 gears it's about as strong as you can make a.toyota case minus the chromo comp gears. It's still going strong, looking back I should have built an atlas but here we are.
I am phone posting all this so bear with me
I take forever to do anything especially build wise. So I drove the truck and wheeled it until 2014 when I swapped in my fj80 rear axle. Everyone said it would vibrate, it infact does not. I stuffed it with a spartan and drove it while I saved up to SAS this bitch. For the jeepers out there this gets a 9.5" ring gear, full float, and disc brakes and roughly 1tonish axle strength.
I also picked up my front axle for the axle swap. Fj60 front axle. Same 9.5" ring gear and uses mini truck outers.
.I take forever to do anything especially build wise. So I drove the truck and wheeled it until 2014 when I swapped in my fj80 rear axle. Everyone said it would vibrate, it infact does not. I stuffed it with a spartan and drove it while I saved up to SAS this bitch. For the jeepers out there this gets a 9.5" ring gear, full float, and disc brakes and roughly 1tonish axle strength.
