marty79
the LS Swap Guy
- Nov 24, 2013
- Conover, NC
It's about that time to get Aluminum setup for my welder, tired of turning away aluminum work lol.
My welder is Lincoln 350MP
Looks like it has a Spool Gun $1400ish
also the "kickbutt?!?!" Push-Pull Gun $2800ish
What do I do? I'm not savvy at all with all the digital settings on this welder and terms and such...I've actually never even messed with anything on it lol. I have set it on one Mig setting years ago and never touched it again haha, it welds amazing with Mig and that's all I've needed it to do.
I've been reading up that the Push-Pull Gun is designed specifically for this machine and it's "digital" adjustments and such but on some forums, I read it gets complex with not only setting it up but also getting the correct parameters set in order to efficiently get the right use out of the $3000 gun for it and this is what scares me I guess.
I guess looking for advise of why go with Push-Pull vs Spool Gun!
(I like the idea of Spool Gun for not having to change wires on the machine since the Spool gun has it's own wire and would make it easy and convenient to weld both Mig and Aluminum while only switching the gas bottle)
***I'm not opposed to buying a separate welder just for Aluminum either if there is a good option. I do have a Hobart 140 brand new, been used once lol, should I get a Spool GUn for that???
Thanks a bunch
Thanks a bunch
