jeepinmatt
..l.
- Mar 24, 2005
- Stanley, NC
I feel bad for the folks who are providing it unpaid.I feel bad for the folks who are paying for this expert service.
They don't, I only charge maybe few hours for crsp like this. Its part of my hassle sometimes with these custom projects, I'm ok with that.I feel bad for the folks who are paying for this expert service.
Stock everything.Does it have headers on it, if so what plug wires?
Swap plug wires and see if the misfire travels with them.Stock everything.
So coils are firing, injector harness side checks out good with the noise light, all wires check to their corresponding place on ecu, all the injectors ohm to 12.0/12.1, but yet somehow 1/7 and 2/8 not working.
Everything is new, plugs, wires, coils, but ill swap em and report back. Can't believe this issue, doesn't add up being symmetrically misfiring on each side!Swap plug wires and see if the misfire travels with them.
No, but I suppose everything needs checkedHave you check compression to start with?
I'm going out on a limb here and guessing you haven't had to diagnose many things. Misfires are only one of a few things, ignition related (coil, plug, or wire), fuel (ie the injector) or mechanical in nature which a compression check or even leak down will give you an indication of what's going on.Everything is new, plugs, wires, coils, but ill swap em and report back. Can't believe this issue, doesn't add up being symmetrically misfiring on each side!
I've done quite a bit of diagnosing but this kinda issue I guess immediately makes me think wiring issue/crosswires/missing wires just because of how it's missing. If it was a "normal" misfire, I wouldn't have hesitated to do the basics but 1 being a v8 swap I'm naturally gonna suspect wiring issue, 2 having an unknown harness and unknown computer made me more suspect of the "swap" components being an issue not engine related...then the final is how the miss is...front and back on both sides just makes you think wires are crossed or something cause that is a weird way to have a mis.I'm going out on a limb here and guessing you haven't had to diagnose many things. Misfires are only one of a few things, ignition related (coil, plug, or wire), fuel (ie the injector) or mechanical in nature which a compression check or even leak down will give you an indication of what's going on.
Ignition is the easy shit to check and usually the first to start with, as mentioned above swap components with a known cylinder that isn't the issue. If the misfire follows the part then you have your answer. Checking for spark should be an obvious one here as well, spark tester or a known good plug laid against a ground. Usually need an extra set of hands so you can watch it while someone turns the motor over. What the spark looks like will also tell you a little bit about coil health.
Fuel is pretty easy, noid light will let you know if the injector is getting power. Stethoscope on the injector while the motor is running can tell you if it's pulsing or not. Again the parts swap method works here as well. If it ends up being a clogged injector just swap them all, don't ever change just one injector unless it's a shit box.
If it ain't fuel or spark related just start drinking beer and know it likely won't be an easy fix, though if it is mechanical in nature you really should've figured it out before all that prior work just based off of how the motor sounds while turning over and/or running.
I'm starting with this first thing todayJust bc the injectors are flashing with noid light doesn’t mean the nozzles are clear and firing fuel.
If the engine sat with ethanol fuel in the injectors, the nozzle can bc clogged with varnish. It may be worth your time/energy to have them tested and cleaned.
They are entering into the arrangement knowingly and willingly.I feel bad for the folks who are providing it unpaid.
so instead of pulling the whole harness apart and wasting time. why wouldn't you check compression (easy to do), Check spark (you said you did), if spark change coils around (just because spark doesn't mean it will fire), pull injectors and see if they are working correctly. THEN try to see if there is a wiring issue.I've done quite a bit of diagnosing but this kinda issue I guess immediately makes me think wiring issue/crosswires/missing wires just because of how it's missing. If it was a "normal" misfire, I wouldn't have hesitated to do the basics but 1 being a v8 swap I'm naturally gonna suspect wiring issue, 2 having an unknown harness and unknown computer made me more suspect of the "swap" components being an issue not engine related...then the final is how the miss is...front and back on both sides just makes you think wires are crossed or something cause that is a weird way to have a mis.
Pulling fuel rail this morning to start there...
In Hp Tuners you can turn off injectors and I'm pretty sure coils as well. Actually quite a few diagnostic tools in the VCM Scanner program, not to mention the 8000 bits of data.Can you actuate each coil or injector driver independently and verify what you think is #7 is actually #7? For example.
Just did, confirmed its the dam injectors lol. Once again lesson learned, start simple. Should've pulled out my noid light from get-go and done this crap.Can you actuate each coil or injector driver independently and verify what you think is #7 is actually #7? For example.
And your whats wrong with America you asshatSorry maybe I woke up wrong side of bed - but I have more respect for a man with a gun and a mask robbing a store. At least that theif is honest and transparent with his actions. This thief is stealing all the same - he just hasn’t admitted even to himself he’s a thief.
It's "you're"And your whats wrong with America you asshat
you're*And your whats wrong with America you asshat
No, you are providing a service and from what it seems not a great one. Then you come on here asking questions on how to fix an issue and by doing so receiving free advice/work from people who normally get paid for this. I am sorry for being an asshole but as a tech of 20yrs it blows my mind that they had to walk you (the business owner and tech) through a simple diagnosis of a misfire.And your whats wrong with America you asshat
