Air shock shrader valve cross reference
Jody Treadway
I'm the big spoon
Moderator
Hendersonville, NC
So, one of my Fox air shock shrader (Schroeder, whatever) valves is bent and won't take nitrogen.
Fox, Poly Performance, etc has them available. But...does anyone know if a more common application for them? Something where I can call up a random local supply house and grab one?
I am going to call my local hose shop in the am.
It's 1/4 or 5/16 NPT on one end and a typical air valve on the other.
Gracias amigos.
Fox, Poly Performance, etc has them available. But...does anyone know if a more common application for them? Something where the can call up a random local supply house and grab one?
Gracias amigos.
Looks like 1/8"NPT, but maybe 1/4. 1/8NPT measures a hair over 3/8" (.405"), and 1/4NPT is a little over 1/2" (.540")diameter. Just measure the diameter. McMaster will almost certainly have what you need. And it typically ships from ATL and arrives next day.
5/16 ORB
What he said but it's probably 7/16-20 #4 sae orb. I've got a lot of plugs and orb to jic but not Schrader. I googled it this weekend and only thing close I could find was for bike shocks.
You could put these two together if you had to.
You're correct. I just checked it with a caliper and thread gauge. 7/16 x 20.
This is why I like this forum. We may be a bunch of dumbasses and smartasses, but when it matters, we are pretty damn useful.
Yup.
Local hose shop said they either have the fitting I need or they can sell me an adapter. Regardless, headed there at lunch to grab a few of them.
Yup.
I'd avoid an adapter for that application, even if it means waiting a few days. Or at least avoid it as a permanent solution.
Can you show a pic of both ends please?
I would call that a Tank Valve. Buy them all the time for our pressurized air jacket tanks. FNPT > MNPT > NPT is the keywords we utilize frequently in that area. The oring is what throws me for a loop tho
It's an ORB fitting, not NPT.
Straight treads.
