Ricky B
Wiiide Open
- Mar 20, 2005
- LKN - Tha Dirty Mo (Mooresville, NC)
Idk, I'm sooo tired of continually trying to keep this damn thing running and it breaking somewhere else as soon as I Fix it . . . whatever Z71's are still that Hotness, and I'd rather push a Chevy than drive a ford, etc, etc . . .
but anyway, its running like crap, loss of power, misfires on hard throttle
Cylinder 7 is not firing, cylinder 5 is barely firing
replaced plugs, wires, cap, rotor button, ignition module with no results
You can remove power to cylinder number 7 while the truck is idiling and it makes no difference, you can also drive around with cylinder number 7 unplugged with no difference compared to if it were plugged.
Cylinder 5 while idling if unplugged makes no difference, while driving with it unplugged it makes kind of a difference in power but not much as in comparison to the rest of the cylinders if unplugged.
So from what I know it seems to me like the only other possible things to try is replace the dizzy itself in case it has a fracture somewhere.
Or to run a compression test on cylinders 5 and 7 to see if I have sticking valves or something causing a loss of compression. Only reason I havn't done so yet is because of my aftermarket shorty headers are in the way and are a PITA to remove/reinstall because the exhaust doesn't line up.
any tips before I drive her off a cliff
but seriously I guess my only other options are to try a new dizzy or run the compression test on the cylinders in question . . . .
Thanks
Thanks
