uglyjeepoffroad
Registered Loser
- Mar 20, 2005
- Hickory, NC
I own 4 chevy's (Z71, 81 Chevy on 44's, 98 4x4 1500, Z71 Jeep)
And you say you still can't sell what you have and buy a tow rig?
I was talking about these.Well I guess if I sold the Jeep too then I could afford a semi decent tow rig but then I would have a tow rig for no reason . . .
I don't know they may charge him to tow them away!If he sold all 3 for their worth hed have 2k max....
x2If he sold all 3 for their worth hed have 2k max....
I bet that new Tundra will pull your chitty and the trailer that it won't pull, and do it without breaking down every week.
air getting from the combustion chamber into the crankcase means its going through the piston or rings. some leak down is normal, but sounds like you've got a bit more than normal. worst case is a small hole in the piston, its more likely just worn rings or the bore is a bit out of round. The cylinder with no compression pretty obviously has a bad intake valve. (or, as was mentioned, the timing chain slipped and your valves aren't closed at TDC)
you hit the nail on the head, its not a timing chain issue, the intake valve has issues. pull the valve cover and see what the rocker assy looks like on that valve.
I wasn't arguing between crate motor/rebuild I was just asking if from what I said from the pressure test if you guys think my motor is done.
I don't know if it leaking a litle air into the crankcase is a killer or if its ok, sound like its not and my motor is pretty much done from what you guys are saying.
But . . . . the main qustion I want clarified is that is my current motor screwed to the point that I have to either replace/rebuild it.
Now, if it is in fact at that point:
I'm def not getting a crate motor thou unless they sell one that has a good amount more power over stock for under a grand.
Like I said, anymore than a grand and I'm not gonna do it, the truck isn't worth putting anymore money than that into, IMO.
And I'm definitly not gonna spend that much money on a motor and be stuck with the same sucky amount of power.
I realize this limits my options, but I'm def not spending money on the motor unless I'm both going up in power and spending less than a grand.
Now, here's the options I'm thinking I have obviously with whatever it will end up costing being the final deciding factor, please commet on the ideas however you think I should go, also bearing in mind I will be doing the work by hand for whatever option except of course for any professional machin work I will have to face.
Your probably still coming in over a grand with a decent machine shop to do it right. You have no warranty and you have small if any gains in performance.- Rebuild to stock with mild cam/intake/chip
A fine option IMHO but aint happening for under 1k. Sorry- Crate motor that has at least 50 HP over stock
Ok so you buy a used motor ($250?)- used 350 that I hop up with a mild cam/intakechip
Second worst idea in your post.- 454 swap
- 383 stroker
- caddy 500 swap
So you are going to spend how much to get a 113,000 mile motor? Damn just buy your rrandom for sale SBC off th baord and take your chances. just as much chance for success.Here's what i'm leaning toward:
- Making 2 good engines outta the 3 that I have:
350 from brown 81 chevy w/ 113,xxx miles weiand intake holley 600 cfm carb
Blown up 95 tbi 350
Vortec 350 w/ 220,xxx miles on it
Thinking 113,xxx mile 81 chevy 350 with the vortec heads with tbi in my truck witch would mean a intake and cam and chip to match.
No opinion;not what this thread is aboutThen the vortec bottom end 81 350 heads/weiand intake carb in the brown chevy.
See above- Another option thinking 383 stroker since I (possibly) have a line on the stroker parts for free, i'd just have to pay for the machining work to my block whitch i have no idea what that would cost if anyone knows?
- Or just find a cheap 350 that used with low miles and throw a cam/intake/chip on it
or the ZZ4 is bolt a carb on and
has a new flywheel, WP new Dizzy everything and BTW its specs 355hp/405lb.ft.
^^^^^^^^^^^^^^Ricky I might just know a guy thats got a 350 vortec with i think it was 40k on it for sale in timberlake(south of roxboro), i dont know why i didnt think of this before.
PM me and ill get in touch with him if you are interested!
aparantly you don't know what you are talkin about or just have had a random bad experience with one.
Preciate the thought man but I have no $$ right now anyway
whatever I do will have to wait till I sell something.
Thats cool, i know he was asking super cheap for it with the headers and ecm and harness and such, ill find out the price for you just in case you get the urge.![]()
