Ricky B
Wiiide Open
- Mar 20, 2005
- LKN - Tha Dirty Mo (Mooresville, NC)
I wouldn't worry about the cylinder with 170 PSI on compression and it seemingly leaking air into the crankcase. 170 PSI is good to go.
Aight, cool, wasn't sure.
Pull the head on the one with no compression and if you are real lucky all you have is a bent valve. Take it to your friendly machine shop and have them fix it. Put the head back on and drive the damn thing. With a little more work, and maybe the cost of another gasket or two, you could pull the other head and confirm that bank is ok.
Thats what I figured its just a messed up intake valve, any idea what it costs to have a machine shop fix the valves?
I really don't understand not wanting to fix the motor now (somehow) yet you are willing to spend money on tires and 'just drive the wee outta it till it blows good' If you don't want to put the money in to it now to fix it are you going to be prepared to maybe spend a lot more a couple of months from now? Doesn't sound like it.
Well I did mention doin something about the valves at least but I was more talking on the lines of I'm not willing to drop in a whole nother motor like everyone elses seems so adament about. And I wouldn't be spending any $$ on tires I already have big tires. My train of thought is more along the lines of not trying to keep my truck as a Tow rig DD, just not really a good idea, at this point id rather just keep it as a toy and just wait a year, year and a half to start makign payments on a new actual tow rig with a warranty, rather than throw several thousand dollars at my rig and still only have a marginal tow rig thats probably gonna break in two weeks again anyway.
If you want to know more about what shape the cylinders, valve, rings, etc are in do a leak down test.
Sounds like a simple problem with hopefully a simple fix to me though.
I will probably do that, then get the valve fixed or slap some good working heads on so that it at least runs well, but hang the hat on trying to use the Z71 as a DD anymore its just not worth it $$ wise, and just jack her up and use her as my random putt around town in Huge truck as well as my Jeep.
