justjeepin86
- Jul 9, 2005
- Winston-Salem, NC
Like the title says. Could a vette ls1 with 450hp run on 87 without crazy detonation? Not looking for the most power out of it.
You can do anything with the right size turbo.Like the title says. Could a vette ls1 with 450hp run on 87 without crazy detonation? Not looking for the most power out of it.
That is not helpful!You can do anything with the right size turbo.
What cam? Cam specs play a big role in compression bleed off.Like the title says. Could a vette ls1 with 450hp run on 87 without crazy detonation? Not looking for the most power out of it.
Did you accidentally fill your dads car up with the wrong fuel and you're hoping to just drive the tank out? (is that more helpful?That is not helpful!
)No. He's gonna be different and swap one into a 98 VetteInternet says it's 10.1 comp ratio. So yes it may be safe with 87 but more engine specs would be necessary to really answer.
So you gonna swap that into the cyj?
No, the vett needs a cummins or that I6 diesel that BMW usesNo. He's gonna be different and swap one into a 98 Vette
Almost certainly heads and cam. That was the magic formula in the early 2000's. Then throw on a 150 shot of Nitrous for good measure and tickle 10's in the 1/4 mile if I remember right.Would all come down to compression ratio.
Stock LS1 was 345-350 hp. So what did the PO do to get those extra 100 ponies.
That would tickle more than 10s for me.Almost certainly heads and cam. That was the magic formula in the early 2000's. Then throw on a 150 shot of Nitrous for good measure and tickle 10's in the 1/4 mile if I remember right.
You're gonna look great in Jorts, tucked in polo shirt and new balance with white knee socks
It's not a vette. It's a swapped volvo wagon with a gto drivetrain. I want a fun daily driver.If running 87 is your qualifier, I wouldn't be looking at a Vette. It'll still find a way to soak up all your money and less than 15 bucks difference, per tank, at the pump won't be it!
What ECU is it running?It's not a vette. It's a swapped volvo wagon with a gto drivetrain. I want a fun daily driver.
You bastard!!! If it's a V70 I've been low key looking for a cheap one to LS swap for the very same reason.It's not a vette. It's a swapped volvo wagon with a gto drivetrain. I want a fun daily driver.
Not sure, but I'll speculate oem. It's all tied in to the obd.What ECU is it running?
Well, you might have a hard time with a v70, they are fwd.You bastard!!! If it's a V70 I've been low key looking for a cheap one to LS swap for the very same reason.
