Tom@Hilltop_Machine
- Mar 31, 2005
- Rural Retreat, VA
It's called a chain fall, very common back in the day. I think I still have oneIndeed. I'll say that thing was a pretty interesting home booty fab contraption.... A big A frame on 4 wheels on rotating casters, no wheel locks or anything. But you can't see is the whole yard is a pretty steep hill. Takes some creativity and profanity to roll around the yard and keep put, but damn nice to have.
At first were a bit skeptical of the manual chain lift, but it probably had a 100:1 gearing or something and worked great.
Once we had it out and dropped it on the ground, they just used a forklift to haul up to the cashier and dropped in my truck. Easy peasy.
Do they use a worm gear? Aside from the insane gear erduction it would also prevent it from being backdriven and falling. First I've used one in this kind of application.It's called a chain fall, very common back in the day. I think I still have one
Actually I don't know. I just assumed they were magic. lolDo they use a worm gear? Aside from the insane gear erduction it would also prevent it from being backdriven and falling. First I've used one in this kind of application.
I've no idea the inner workings. But I've got 4 in the work truck and we have a connex full of them from out field crews. They'll wear your arms out flying stairs up 3 floors, buy it beats the alternative. They finally got smart and bought a 150' electric chainfall. Throw up a beam across the shaft and you're set for 10 floors.Do they use a worm gear? Aside from the insane gear erduction it would also prevent it from being backdriven and falling. First I've used one in this kind of application.
Mine is slow as a turd but haven't found anything it want lift.It's called a chain fall, very common back in the day. I think I still have one
Skip to about 1:45 into the clip.
Jokes on you bud. I’m off today and you will have to deliver to 4 Latinos.Gonna give @frankenyoter 30 butt pilings today. 8" at a time.
I better hydrate first
Muy grande is all I recall hearing!Jokes on you bud. I’m off today and you will have to deliver to 4 Latinos.![]()
Your penis does NOT go inside of thatFuck this thing, View attachment 446124If you know you know
D44 upper BJ in the works?Fuck this thing, View attachment 446124If you know you know
BJ?D44 upper BJ in the works?
Yes, I wanna call an upper ball joint preload? Adjustment thingy
I broke 2 tools loosening some until I got an otc brand toolYes, I wanna call an upper ball joint preload? Adjustment thingy
There’s a joke somewhere here. I just can’t find it. (Like the driver and the camp spot)
