Shreddinlettuce
- Nov 20, 2016
- Hickory
Mmmm rice crispies, and some snap crackle pop welds
pink of courseNice steering wheel. Now for the hockey tape
Whats the details for this? Did you make it or buy it? What steering box are you using? I'm wanting to do something similar on my TJ.
davescustomsunlimited.myshopify.com
Ian Johnson did a review of several paints for welding over them. He also did not like the steel-it. He recommended the Seymour paint and so far has seemed to work ok for me.I call bs on steel it being weld through. I tried to coat all of the areas I can’t get to later. But that stuff makes for a lot of porosity. I did a really quick spray to make it as thin as I could. Looks like I’ll be spotting and grinding the welds smooth…View attachment 448093
It was a can I already had from doing sliders on an xj a few years back, I had similar results but thought it was how thick I applied it. This experience verifies it does not live up to the marketing. I will look into that stuff for the next projectIan Johnson did a review of several paints for welding over them. He also did not like the steel-it. He recommended the Seymour paint and so far has seemed to work ok for me.
I haven’t had luck with any weld through paint eitherIt was a can I already had from doing sliders on an xj a few years back, I had similar results but thought it was how thick I applied it. This experience verifies it does not live up to the marketing. I will look into that stuff for the next project
Lucky there’s enough inches of weld I’m sure it’ll be just fine, but I would’ve liked to leave them whole and not ground smootheI haven’t had luck with any weld through paint either
What clutch you running?
I’m gonna put .5 of spacer under the trans mount, there plenty room for the atlasCan you notch the skid plate? Or is the gap ok?
