WARRIORWELDING
Owner opperator Of WarriorWelding LLC.
- Jan 6, 2008
- Chillin, Hwy 64 Mocksville NC
Big girl had a bad day!
"I like big butts......"
Not anymore! Healing regimen is underway.Wow.
Das a big crack![]()
It had its moments. One area it pulled some nasty crap out of the plate the fella provided. I had ground the back chasing back heavy rust. It was some stuff he had laying about. I guess I didn't hit the back side hard enough in that area. Another area I had not cleared the factory paint quite wide enough. It chewed through it but really disturbed the arc and puddle flow. It is a bit finicky with wind. I had to gouge out a couple passes before I got mad enough to eat a nab and put up some wind blocks. Absolutely a gas hog and is happy running 25-35 cfm on flow. With a small nozzle and the wrong angle it is enough to pull ambient air into the puddle! Drag, pull, push it doesn't much care just changes the profile of the bead.What do you think about the 7100? Not so much on the shielding gas side but the weld quality on possibly less than ideal surface prep situations?
