What brand throttle cable bracket is that?I got the throttle all hooked up. That’s about all I completed this weekend.
View attachment 446268View attachment 446269View attachment 446270View attachment 446271View attachment 446272
Thanks!Amazon.com: YzusGomumu 304147 EZ EFI Car Cable Mounting Kit Carburetor Throttle Cable Mount Bracket Steel Black Adjustable for Automatic Transmission TV Cables for GM 700R4 Transfer : Automotive
Buy YzusGomumu 304147 EZ EFI Car Cable Mounting Kit Carburetor Throttle Cable Mount Bracket Steel Black Adjustable for Automatic Transmission TV Cables for GM 700R4 Transfer: Linkages - Amazon.com ✓ FREE DELIVERY possible on eligible purchasesa.co
Can the whole pump be rotated 90 degrees so you only need the one elbow?Was finally getting the fuel tank mounted up and the return line, right side in the pic, is too tall and hitting the floorboard. I've gotta rethink my fittings here to get this flush with the top of the tank.. I'm sort of thinking I can ditch the 90 and attach the hose straight to the 45, but this hose isn't very forgiving and I don't know if my routing will work with that plan.
No it's indexed to reach a sump in the middle of the tank.Can the whole pump be rotated 90 degrees so you only need the one elbow?
Put another 45 on it and lean it any way you want.Was finally getting the fuel tank mounted up and the return line, right side in the pic, is too tall and hitting the floorboard. I've gotta rethink my fittings here to get this flush with the top of the tank.. I'm sort of thinking I can ditch the 90 and attach the hose straight to the 45, but this hose isn't very forgiving and I don't know if my routing will work with that plan.
Crazy that getting the gas tank in is a win, but here we are.
It’s “mocked” right now. I connected the fuel lines to make sure they cleared but didn’t connect anything else because I was tired of the back and forth.
View attachment 453270View attachment 453271
It's R (space) Q because RQ wasnt enough lettersI didn’t snag a picture, but @RQ I ended up replacing the 90 with a 45 on the return and replaced the supply side with a 90 off the 5/16 tube.
Meant to hit edit and not reply … also why didn’t it tag with the @ symbol?
