Chainsaws
I thought about putting a zip tie on the pick up. Not following the fuel puddles.
Over rich condition. Unburnt fuel puddles in the case. It gets pulled into the combustion chamber on the Two Stroke Cycle.
@ponykilr wouldn't that usually also accompany a little excessive smoke and a rich plug? With mixes being way less smokey by nature tuning one using the color of smoke as a guide is dead art.
@ghost flooded cases and even cases that leak are usually over looked by the average joe. I didn't know much about symptoms of either til a saw of mine seized with low hours. A leaking case will allow air to be pulled in, usually never pushed out. Air then leans the saw. You either chase what you think is a carb adjustment or its subtle enough it runs like a scalded cat until it doesn't.
You covered it pretty much brother.
A saw that is set slightly rich to cover an unknown air leak will puddle fuel in the case but idle ok…..maybe up and down a bit. Tilt it on it’s side to notch a tree and it’ll suck in some fuel and sputter or die. The air leak itself depending where it is can also cause a stall when tilted over as it goes lean (or rich if the saw is set to cover a leak that goes away when tilted)
Can be crank seals worn, air horn or associated stuff between carb and cylinder, impulse line ect.
Another possibility is some Husqvarna saws have a carb not directly vented on the diaphragm cover but they use a port in the intake. These are notorious for weird carb/running problems that come and go (359s are good examples). The fix is to drill a 1/16” hole in the diaphragm cover like God intended.
Tuning….
The difference between a saw that is as from the Lord or one you offer to Satan 😅
I never tune for smoke (sometimes smell at idle if it is a very small saw) but adjust low for cleanest highest idle and high til it screams at WOT and then back out (corrected) til it begins to burble at WOT. Go back and forth maybe 3 times between screws to fine tune as each affects H&L a little bit.
Big saws like 70cc up sometimes need a minor tweak on the H screw in the cut to get it to really sling chips.
Mtronic saws are magic and I LOVE them because they are never out of tune, even adjusting themselves in the cut from the top of a log to the fat part.
That’s what I’m thinking. I pulled the original off and it was cracked where the filter connects. Probably my issue all along. I ordered Stihl pick up today. Only $20 gamble.
Didn’t see this part. Amazon fuel pickups are typically garbage.
I've got a Stihl one on the way. This is on my 460 Magnum. I dropped off the 361 yesterday to see what the dealer says it needs. It was $200 off MP so not scared to invest some in it to get it running better.
I love the idea of Mtronic but the MS661 I had with it was too dang finicky. Any change in the fuel would make it cut off after a few minutes.
Tuning….
I never tune for smoke (sometimes smell at idle if it is a very small saw) but adjust low for cleanest highest idle and high til it screams at WOT and then back in til it begins to burble at WOT. Go back and forth maybe 3 times between screws to fine tune as each affects H&L a little bit.
Have you ever tuned with a rpm gauge?
The carb solenoid has gone through at least 3 iterations. Early saws had some issues but the latest solenoids are phenomenal. My 261C is absolutely unflappable.
Messed around with them but RPM on a saw with age or mods of any kind is a crap shoot. H screw in to clean scream and then out til it burbles. If it seems to stall too easy when you push it in the cut sometimes a tiny bit more fuel (out) will make a big difference….mostly on bigger saws because unless you’re my dad (RIP) you probably don’t bury small saws in green oak 😅
Pretty much you want a white solenoid.
You got two choices IMHO. Just cut the back and let it fall. Or cut a small notch where you want it to go then do a back cut. IF you cut a notch be prepared to pinch the saw and have to cut it out and possibly loose the saw. JMHO.
If you want to drop it towards the stump in the second picture, I would try to put a notch in the tree where it goes vertical after the bend where most of the rot is. Put a tension line on it to keep the bar from getting pinched. All this is assuming that the height is managable in a safe capacity.
Otherwise, @ghost is right on the money (at least, it is what I would also do).
How does one tell this tree safely?View attachment 454555
I think you can tell it whatever you want. ;)
Safest way to do it is to pay someone else. Hard to tell from the pics, but looks like its weighted towards the stump in the second picture. If so, I'd make a notch in the direction it naturally wants to rotate, fairly shallow, like 3" or so, just enough to relieve the pressure. If you have a way to tension it in that direction with a rope tied up high, that would help, but don't do that until AFTER you make the notch, and don't use a bunch of tension, just enough to encourage it. Then make the back cut at a quick pace and be prepared to make distance between you and the tree when it starts to go because its likely to barberchair or go in a weird direction. Cutting the back cut slowly will be more likely to barberchair, so don't be too slow. Whatever you do, do not try cutting anything about that tree on a ladder.
Or winch the shit out of it and pull it right over.
First, you get on a really tall extension ladder....
Just a small notch if at all then start the back cut. The wood looks too rotten to barber chair but keep your face back anyway. You'll be fine. I use a snatch block and the winch on the jeep a lot for sketchy stuff and it works great.
based on the rot, id probably first try a rope above the knee and a winch from a safe distance and see if it would just fall, then buck it up on the ground.
Similar to others opinion.
If that tree was at my house, and I was trying to get it to go a specific direction, I would put a ladder up against it and wrap a strap around it up high, then hook the other end to my come-along the direction I want it to go and tighten it up just enough to get the slack out, then cut a small size notch the direction I want it to go, then tighten the shit out of the come-along, then back cut it. Sometimes I have sort of 'over correct' with the direction the come-along is pulling based on the lean of the tree and the angle I want it to fall.
Few 30 round mags from a little distance.
