Random pic thread.
Birds caught my eye as I drove by this place.
Had to turn around and get a picture:
Went by an hour later to see if I needed to call in a wellness check and they were all gone and the red mustang was gone.
Any idea what front fenders those are?
But they are nowhere to be found on their website. The Cab and Chassis F450/F550's have wide black fender flares in the front if you just want something like that:
Not sure what to do with the rear fenders though. Or maybe Tremor or Raptor flares? F150 and F250 share a lot of body parts.
The wheels on them were made by buckstop truckware, so maybe from them?
This. I am currently installing a kit from them on a Dodge 5500. It will be on 43's . Edit: these require firewall cuts and mods along with the fender cut and hacking up the inner fender liner.
The kits are stupid expensive. Been waiting on replacement fenders from them for a while now. The first units got killed in shipping. They build the bumpers too to match the finished width.
You can hack them up proper.
Both these units got the factory flare mods I came up with. Lot more meat with lot less lift....but man do they suck to get done.
Do any of these departments actually take these trucks anywhere that would justify the expense of the conversion?
I know I've personally seen one used to keep a forest fire from happening when an excavator went up in flames clearing trees about a mile from a gravel road. No way any other fire service vehicle could have made it.
But would that same truck as a stock dually with 35-37” mud terrains be able to accomplish the same task?
Results vary. I know of one department who has a build (very recent) knows how to blow out the front end!
I’ve been keeping an eye out for cut out flares for my 2021, but haven’t seen any. Bushwacker and few companies make them for the older trucks but I couldn't find any for a 2021 body style F350. That’s why these caught my attention.
View attachment 456895View attachment 456896
View attachment 456897View attachment 456898
What about clearance for the radius arm links or leaf springs and anti sway bar mounts when turning? Not as familiar with the ford variety, but the tire diameter limit on rams is usually related to full lock turning radius right?
Going to a super single moves the wheel offset like 6-7 inches outward which gives clearance on the hard parts. Also bringing the wheel on center instead of inset like a dually reduces how much it swings forward and back which helps with fender clearance when turning. You can run 35s bone stock on a cab and chassis truck without any clearance issues with dually wheels, so 40s would probably fit in a super single configuration.
