- Apr 16, 2005
- Sharon, SC
Understood. See also Data Center Guy, I.E. Computer Geek.R-454b has an ignition temp above 900 degrees. I don’t really see that being an issue.
I came here to say the same thing. A good friend of mine just did his house himself, two units, and after having the "professional" do his part my friend was out of pocket maybe $10kBuy one online and do it yourself. Have a guy hook up the lines and charge it. That's what I'm gonna do. My mil just paid 15k for one,for a 1200sf 1 level, but I think she got hosed.
I'm looking here. A buddy went this route and replaced his for about 5k. He had a 23k quote, which was a little high.
Purchase Your HVAC Equipment Direct | Mitsubishi, Trane, and Goodman AC And Furnace | HVACDirect.com
Buy HVAC equipment direct at wholesale pricing. We sell Goodman furnaces, Goodman air conditioners, Goodman heat pumps, and other HVAC equipments. Shop online now with HVACDirect.hvacdirect.com
I can feel that disc on the power meter spinning for hours in my bones. I'm sure my Emporia app (thanks again @kaiser715 ) could tell me exactly what it costs to run all day just to keep the house at 76 but I don't even want to know....
Did you install the whole system in your panel? Looking in my panel, there isnt much room inside it for anything else.This is the battle I keep facing.
I keep a box of spare parts on hand, all the usual suspects listed previously, which cumulatively cost less than $100 to have just sitting and at this point I know exactly how to change everything.
However at this point its the terrible efficiency thats killing me. I can feel that disc on the power meter spinning for hours in my bones. I'm sure my Emporia app (thanks again @kaiser715 ) could tell me exactly what it costs to run all day just to keep the house at 76 but I don't even want to know....
Chances are I will do something like that. Last Fall I met an HVAC guy that works for a company but has his own side gig selling / helping to DIYers and showing them how to do stuff. I could definitely see going through him for getting proper info on sizing, model etc and doing the hookup and charging.
But I suspect I'll need the condenser coil changed too and I don't know if I want to get into all that.
updated heat pump and water heater in recent years without much change
You jinxed me. Haven't even thought about the Emporia in a while. Then, tonight I get an alert from it. Septic pump again. Usually averages 0.15kw per day. The alarm was for Tuesday 17.5kw, and Wednesday 20.5kw. Hopefully it's not the $2k pump again.
At least it was a cheap and easy fix!Ten cent zip tie. Float switches were tied to a chunk of PVC. After we replaced the pump, I was going to go in and fix it right rather than the half ass way it was originally setup. Of course, it was never done. Zip tie holding the coiled-up excess wire broke, and tilted the whole thing over. We didn't take care of it right when we did the pump because it was 33 degrees and raining.
Or maybe insulate it to decrease the thermal loss so it runs less but that's not going to be massive either and depends on the location etcAnd unless you went to a heat pump water heater, it's just a resistance element that's going to use 5000 watts every time it kicks on. Only way to save money there is to turn down the thermostat or use less HW
75% of it.Did you install the whole system in your panel? Looking in my panel, there isnt much room inside it for anything else.
I feel like I should do something similar to track power usage. I have updated heat pump and water heater in recent years without much change.
Not really going to make a difference.Or maybe insulate it to decrease the thermal loss so it runs less but that's not going to be massive either and depends on the location etc
This post is akin to plucking a strap and saying that ain’t goin no whereI have a heat pump, been in house since 84, replaced compressor 4-5 years ago. Was r22, now running with MO99. Stilling running original condenser fan motor.
They've only had their septic tank pumped once in 40 years also. And their well water tastes great and doesn't need filtration. Sometimes you just win.This post is akin to plucking a strap and saying that ain’t goin no where
We had ours pumped when we bought the house (or rather, the PO did). The guy mentioned that it needed to be done every five years. I was curious, so I asked what happened if you didn't. He says, "oh, you end up with this dense layer of solids at the bottom of the tank and it's a real pain to clean out." I was like, cool story, bro. See you in 20 years!They've only had their septic tank pumped once in 40 years also.
That guy is a moron. This is what happens when a tank isn't pumped for routine maintenance. Solids build up to the point they start flowing into the drainfield and clogging it up. $400 every 5 years or $10k plus for a repair after 20 years of no maintenance, seems like an easy choice.We had ours pumped when we bought the house (or rather, the PO did). The guy mentioned that it needed to be done every five years. I was curious, so I asked what happened if you didn't. He says, "oh, you end up with this dense layer of solids at the bottom of the tank and it's a real pain to clean out." I was like, cool story, bro. See you in 20 years!
"Yeah but that's only my problem if I plan to be here in 20 years!"That guy is a moron. This is what happens when a tank isn't pumped for routine maintenance. Solids build up to the point they start flowing into the drainfield and clogging it up. $400 every 5 years or $10k plus for a repair after 20 years of no maintenance, seems like an easy choice.
You're not wrong, and with a lot of people struggling to afford groceries, there has been a significant drop in maintenance pumping in our area."Yeah but that's only my problem if I plan to be here in 20 years!"
They've only had their septic tank pumped once in 40 years also. And their well water tastes great and doesn't need filtration. Sometimes you just win.![]()
then one day their toilets backed up
