I’ve been replacing all the worn out shifter joints on my ambiguously gay duo car with fancy race car stuff only to look over and see the drivers side wheel cylinder leaking on the Jeep.
I briefly considered doing a disc brake swap then looked at pricing on swap kits.
I hate drum brakes.
got the rebuilt transmission back in and atlas in, linkage done. damn I am to old to do this shit on the floor.
Got the alternator back from the rebuild shop; I accidentally cooked the regulator due to a faulty instrument cluster shorting out the charging circuit, battery was iffy but after setting on a good charge it's passing load tests.
Started in on my headlight wiring upgrade; adding relays and larger wire to take the load away from the switch and put 12V to the headlights. Going from 18Ga to 14Ga for the power leads and 12Ga for the grounds,
I'm still not 100% on the relay location, it'll be a bank of 4 relays controlling the high beams, low beams, 4-Hi, and fog lights. I'm torn between mounting them under the PCM or on the side of the underhood storage box; I'll probably make a little bracket to mock up for final fit.
I'm hoping to have the front end put back together in the next week or so; I'm stuck waiting on the proper weatherpack crimper and a few wiring supplies before I can get everything assembled
